UPDATE - 22 Oct. 2012
The latest beta BIOS versions should add support for the new Vishera FX processor! See below for information
The boards without VRM cooling (970A-D3 rev 1.0/1.1/1.2, 970A-DS3) have NOT been updated for 125W 8-core Vishera FX processors
Blue rules!
Gigabyte 990X and 970 chipset board owners, here you may discuss your experiences, problems, or whatever you see fit for discussion, as well as find out the latest news and information about your board. For everyone else, you are welcome to join us too!! Without further ado, I would like to now welcome everyone to the GA-990XA/970A-Series Owners Thread/Club.
This owners thread/club concerns the Gigabyte 990X and 970 chipset boards board released so far: the Gigabyte GA-990XA-UD3, the GA-970A-UD3, the GA-970A-D3 and the GA-970A-DS3.
[CLICK HERE] for the Gigabyte GA-990XA-UD3 CPU model support list
[CLICK HERE] for the Gigabyte GA-970A-UD3 CPU model support list
[CLICK HERE] for the Gigabyte GA-970A-D3 CPU model support list
[CLICK HERE] for the Gigabyte GA-970A-DS3 CPU model support list
Board specifications:
Gigabyte GA-970A-D3
Members list
People who want to submit for membership to the GA-990XA/970A-Series Owners Thread/Club may do so at [CLICK HERE] to visit the submit form. To be a verified owner (highlighted in orange), you must have a CPU-Z validation link, and must prove that your validation is stable (if overclocked) by providing a screenshot regarding stability in the thread. The screenshot may feature either Prime95 after minimum 3 hours, IntelBurn or LinX after 20 passes on high, or OCCT for 30 minutes.
As a unique feature of this club, we are allowing you to submit your info as a "future" owner, in case you have upgrade plans to a GA-990XA or GA-970A Series motherboard.. However, we ask that all "future" owners ask for inclusion into the spreadsheet by posting in the main thread and not using the submit form.
GA-970A-UD3 unboxing on privatepinky channel
Useful tools & tweaks
Overclocking and monitoring tools
Monitoring tools
Stability testing tools
Performance testing tools
Other Information
Blue rules!
- AM3+ socket
- Support for 32nm AMD FX-Series 4-core, 6-core and 8-core processors (Bulldozer and Piledriver core)
- Support for AM3 Phenom II and Athlon II processors
- 8+2 phase power/VRM with heatsink cooling, and 140W CPU TDP support
- 4x 1.5V DDR3 DIMM sockets supporting up to 32GB of dual channel memory
- Native support for DDR3 at 1066, 1333, 1600 and 1866 Mhz; can support higher mhz through overclocking
- AMD 990X northbridge chipset and AMD SB950 southbridge chipset
- Support for AMD CrossfireX and nVidia SLI at 8x-8x using PCIEX16 and PCIEX8 slots
- Support for 6 SATA6GB/s devices, as well as RAID0, RAID1, RAID5, RAID10 and JBOD
- Up to 14 USB 2.0/1.1 ports (8 ports on back panel, and up to 6 through internal USB)
- Up to 4 USB 3.0/2.0 ports (2 on back panel, 2 through internal header)
- Integrated Realtek RTL8111E LAN
- Integrated Realtek ALC889 HD audio
- Up to 7.1 channels
- Support for S/PDIF out
- Support for Dolby Home Theatre
- Expansion slots:
- All PCI-E Express slots conform to the PCI-E 2.0 standard
- 1x PCI-E x16 slot running at x16 (reverts to x8 in CrossfireX/SLI mode)
- 1x PCI-E x16 slot running at x8 (when used)
- 1x PCI-E x16 slot running at x4
- 2x PCI-E x1 slots
- 2x PCI slots
- ATX Form Factor; 30.5CM x 24.4CM
- Rev 3.0 boards have UEFI support with dual UEFI BIOS
- AM3+ socket
- Support for existing AM3 Phenom II and Athlon II processors
- AMD 970 northbridge chipset and AMD SB950 southbridge chipset
- Support for AMD CrossfireX at 16X and 4X using PCIEX16 and PCIEX4 slots**
- Please note that a 4x PCI-E link will bottleneck graphics cards more powerful than an HD 5770/6770
- Expansion slots:
- 2x PCI-E x1 slots
- 2x PCI slots
Gigabyte GA-970A-D3
- AM3+ socket
- 4+1 phase power/VRM with no cooling, and 140W CPU TDP support except FX-83XX (a notice about VRMs: it is highly recommended you ensure VRMs are cooled when overclocking any high wattage processor. For more info see here and the notation in the questions & answers section below)
- NEW - Rev 1.3, 1.4, 3.0 GA-970-D3 have VRM heatsink cooling installed
- Expansion slots:
- 2x PCI-E x1 slots
- 2x PCI slots
- AM3+ socket
- Gigabyte Ultra Durable 4 Classic PCB
- Expansion slots:
- 2x PCI-E x1 slots
- 2x PCI slots
Members list
- AMD Overdrive - Software overclocking and monitoring. NOTICE: It is recommend that permanent overclocking be done in the BIOS, not with software!
Monitoring tools
- HWiNFO - A free, fully featured, and all around useful tool for viewing and monitoring system information. It has similar features as CPU-Z, HWMonitor, and EVEREST/AIDA64. It shows detailed information about motherboard, CPU, GPU, RAM, BIOS, hard disk drives, etc. It can be used in any Windows version above Windows 2000 or DOS, and comes in a portable version.
- CPU-Z - View important system specs such as CPU speed/details, motherboard, memory, graphics.. etc
- HWMonitor - View voltages, temperatures, and control your PWM fans.
- CoreTemp - Accurate CPU temperature monitor. Also download the CoreTemp desktop gadget for Windows!
- SpeedFan - Tool to control PWM fans - can also monitor temperatures.
- IntelBurnTest/LinX - Short, stressful linpack-based tools - great for testing CPU stability. Notice: Usually runs hotter than other stability tests.
- Prime95 - A well-accepted stress testing tool, runs a prime number calculation as a stress test over multiple hours to determine stability.
- OCCT - A stability testing tool with many different programs. Uses a prime number test for the CPU and a Linpack-based test for the memory. It also tests GPUs with a Furmark-style test, and the power supply with a combination of the above.
- SuperPi Mod V1.5 - Great tool for testing memory stability (at 32M setting). This single-threaded benchmark calculates the value of Pi to millions of digits.
- GeekBench - well known tool that tests CPU performance and memory bandwidth with a number of quick tests
- MaxxMEM² - Memory bandiwdth and latency testing tool
- SuperPi Mod V1.5 - This tool also responds fairly well to changes in clock speed and memory. Notice that due to code optimizations it is not to be used for cross-platform comparisons.
Other Information
- If you are not on the members list, you may add yourself by visiting this link.
- If a change would like to be made in your membership information (i.e. from future owner to current owner), PM me (xd_1771) so I can change your information in the spreadsheet.
- Feel free to PM me (xd_1771) if there are any concerns about the thread, or if there are any improvements/additions you wish for me to make.
