Ovethaul my original corsair 750d. top rad?
456 views 4 replies 2 participants last post by  Roboyto
#1 ·
i wanna go with a 3 fan rad inside on top, as wide as the case can handle.
should fit, correct?
i wanna go thin cuz 3 x 140, i'll be able to cool the cpu & gpu.
atm i have 2 x 240 rads just for the cpu. max temp 80c @5GHZ.
old photo, but have a 3060TI FE ima put a water block on.
ima remove bith rads and use link above.
#2 ·
I would think dual 240mm would be enough to add a 3060 Ti.
I had 5900X + 2080 Ti cooled by dual 240mm with an Alphacool Eisbaer pump/block/res combo. Radiators were 10+ year old XSPC EX240. Top radiator was using 15mm slim fans due to the ancient Corsair 350D case. Front had "generic" PC-Cooler ARGB fans.
Is CPU delidded for liquid metal upgrade? Makes quite a difference even with stock IHS.
  • Helpful
Reactions: austin86
#3 ·
the 3770k is delidded. but my current i5 is not and is water cooled as seen in my profile photo. i'll repost soon with info.
