Hi all, after numerous build, for some reason I've built a lemon this time around and with lots of issues. While I think I'm nearly on the home straight but one that has been a consistent issue is the GPU (Gigabyte Winforce RTX 4060ti 8gb) and the persistent nvlddmkm Event id 153. I could be playing a game and it will freeze, alt-tabbing can make it happen or it could be Youtube. It doesn't normally cause a hard lock where it needs to reboot, but enough to be an annoyance.
After doing some research I was shocked to find so many people with this issue, even back from 2023 with much older drivers. The PSU seems solid, cables are fine, re-seated, temps never get about 64c. Clean Windows install, no internet and Nvidia drivers, tried DDU, re-installed. Rebar/4G on and off, and full permissions on the nvlddmkm file. I've run a memtests, lots of prime95's no issues what so ever. Swapped the ram sticks around.
Curious if others had this issue? I've ordered a 7700XT with the mindset for returning the 4060ti, but I did want DLSS.
