Philips Brilliance 349X7FJEW - New WQHD ultra wide monitor with 100hz
4.2K views 13 replies 4 participants last post by  Malinkadink
#1 ·
Long time lurker, first time poster.
I'm looking for for a WQHD ultra wide monitor with at 100hz. As of now it stands between Samsung C34F791, AOC AG352UCG or Asus MX34VQ.
But suddenly a new monitor came up on my price comparison site, and it's cheaper than all of the monitors mentioned above (at least here in Norway, about $35 cheaper than Asus MX34VQ).
I don't find this monitor mentioned anywhere other than different web shops.
Noticeable specs for Philips Brilliance X-line 349X7FJEW:
LCD panel type: VA LCD
Panel Size: 34 inch / 86.36 cm
Curved Screen: Yes 1800R
Optimum resolution: 3440 x 1440
Response time (typical): 4 ms
Contrast ratio (typical): 3,000:1
Signal Input: DisplayPort 1.2, HDMI 1.4 x 1, HDMI 2.0 x 1
Noticeable techs and other stuff:
Adaptive Sync Technology: AMD FreeSync
Flicker-free: Yes
Picture enhancement: SmartImage game
USB 3.0x4 (1 w/fast charging)
Built-in Speakers: 5 W x 2
More info: http://www.philips.com.sg/c-p/349X7FJEW_00/brilliance-curved-ultrawide-lcd-display/specifications
What do you guys think?
I guess it's hard to say if this got anything to compare against the other monitors except price, but if anyone got anything please share
#3 ·
Originally Posted by Graploos View Post
This is now available for preorder in the Netherlands for 820€, thats pretty cheap.
Anyone found any more information yet?
I guess we won't hear anything before someone gets their hands on it. Here in Norway one webshop expect the monitor to arrive this week already, but others isn't expecting before May.
It's not an very exiting monitor, except the price and I like the style, but if it ranks over Samsung and Asus in future reviews I may buy it.
#4 ·
Doesn't look like it's a 100hz monitor which explains why it's cheaper.
#7 ·
#8 ·
I got a reply from Philips if this monitor supports 100Hz native:
For 349X7FJEW, both DP1.2 and HDMI 2.0 port can support 3440x1440@100Hz. There is no relation between Freesync and 100Hz
#10 ·
That's a bummer if you were planning on buying. I'm still "window shopping", waiting for more hands down reviews while im also waiting to see how Vega will preform as I will need a new card to run a monitor like this.
#12 ·
So just got this monitor.
It definitely does do 100hz at native resolution.
Some quick thoughts( when comparing, it's to my older philips MVA from 2012)
  • Contrast is definitely worse on the 34"
  • Has more glare problems
  • Build quality seems good
  • Looks nice
  • Haven't found any dead pixels
  • Interface is simple, works with just 1 button/joystick idea
  • Needs be in 'fastest' mode to remove artifacts
  • Does 100hz
Anyone want me to run any specific tests?
--edit--
Monitor seems to have issues with freesync. It makes the screen flicker.
Also noticed some build quality issues on closer inspection. Not all plastic parts fit together nicely.
There is also some room between the panel and the bezel on the lower part of the screen.
Will be sending this one back
#13 ·
Ah too bad
Are you witing for a new one, or will you go for a different monitor?
I'm thinking of buying the agon ag352ucg, it's on sale this weekend at the same price as this monitor, and then I could just go for an nvidia card instead of waiting for Vega.
#14 ·
I just came to laugh that they're still making ultrawides that are 100hz and not 144hz, when we're about to get 4k 144hz. I know 21:9 and 16:9 isn't the same thing, but 3440x1440 144hz is less bandwidth than 4k 144hz by a significant margin yet they're still content giving us 100hz. Ew.
