1 - 9 of 9 Posts
Ekor
Discussion starter · #1 ·
Hello,
I'm experiencing eye problems from my lcd monitor and my new desktop. When I plug my monitor into my old desktop the image is very easy on the eyes. But the new desktop seems to have more flickering and this is hurting my eyes.
The older desktop has a stronger psu (450 W) than my new one(300W). My new graphics card just installed reduced the flickering by a little but I suspect the weaker power supply unit is the cause of this bad screen.
Would getting a stronger psu reduce the flicker?
Thanks
The GPU might not be getting enough power. 300W isn't much, especially if the PSU isn't any good.
Can you give us the system specs (need to know maker of PSU).
The system will draw what it needs, if the PSU is getting overdrawn then it should* shut down.
*should, implying what's supposed to happen, but the unit is unknown so far
Discussion starter · #5 ·
Hi,
My graphics card requires minimum of 300 W of power, and my psu is exactly on 300W. So it's right on the line, and I suspect that it would be better to get a stronger psu just to have an optimal performance. It wont shut down the computer, but it may not be giving ideal power for my gpu. Before I installed the graphics card the flicker was far worse on the built in gpu on my processor.
My monitor does not flicker as bad on my older cpu, which has an older GPU but a stronger power supply unit.
Specifications:
Brand
ASUS
Model
ENGT430 DC SL/DI/1GD3
Interface
Interface
PCI Express 2.0 x16
Chipset
Chipset Manufacturer
NVIDIA
GeForce GT 430 (Fermi)
Core Clock
700MHz
CUDA Cores
96
Memory
Effective Memory Clock
1600MHz
Memory Size
1GB
Memory Interface
128-bit
Memory Type
DDR3
3D API
DirectX
DirectX 11
OpenGL
OpenGL 4.0
Ports
HDMI
1 x HDMI
D-SUB
1 x D-SUB
DVI
1 x DVI
General
RAMDAC
400 MHz
Max Resolution
2560 x 1600
SLI Support
No
Cooler
Fanless
Dual-Link DVI Supported
Yes
HDCP Ready
Yes
Card Dimensions
7.3" x 4.4"
Features
Features
Effective and quiet DirectCU Silent 0dB thermal design
Pump up graphics performance with Super Alloy Power that delivers 15% Performance boost, 2.5 longer lifespan, 35C cooler operation
That 300 watt recommendation is for the card plus the rest of the computer, and on top of that it is exaggerated to cover people who buy really cheap power supplies that can't supply their stated maximum. The GT 430 really only draws barely over 20 watts under load, so there's no need to worry about that.
Getting a more powerful PSU will not improve the performance of the card.
Discussion starter · #7 ·
When my computer was plugged into the power bar, the flicker was much worse. When I plugged it directly in a wall socket then the flickering reduced, that's what still pushes me to believe it's the power supply unit. I'm just hesitating to switch because I'll void the warranty, but thanks for the input.
Depends on what sort of flickering... The screens at college sometime flicker cos the screen PSU goes nuts.... Might be a cable is loose, I have had that before...
TBH, I have no idea. Cannot think for the life of me why a screen would flicker. Does the computer work fine on another screen?
1 - 9 of 9 Posts
