1 - 1 of 13 Posts
Originally Posted by JagYui View Post
Use the .exe to extract the files to your hard drive, but do not run the DS3 Tool executable. Instead, use the Device Manager property sheet to install the MiJ drivers manually to both your DS3 (while plugged in through USB) and to your bluetooth adapter. They are located in the install path for MiJ in the folder \ds3\drivers\.
Uninstall MiJ and use Better DS3 to create configurations.
Wow, great find. Thank you.
Side note, if you ever had motionjoy installed theres no need to even reinstall the drivers.
1 - 1 of 13 Posts
