Hello!
I'm in the process of researching a future, much needed platform upgrade. I have my CPU mostly narrowed down (I'm going with Ryzen 7 3700X unless the 3800 XT refresh is confirmed, soon, and ends up being worthwhile?) but I MAY upgrade to Zen 3 later. But a Zen 2/Zen 3 eight core CPU is what I'll be working with to cool.
I have my RAM chosen.
Given how long I've waited (I'm using a Core i5 2500K), I've decided to wait for B550 boards (I erroneously didn't know B450 would be good for Zen 3 until recently, and X570 pricing and availability was spotty, plus the fan potentially adding noise was a turn off). So, I figure I'll wait a week and some and hope B550 availability and prices are nice, and I'll look into boards soon.
Speaking of which, that leaves one thing left, and that is the CPU cooler. That is what this thread is for and where I need the most help. My primary concern is noise. It does not have to be silent! I would prefer if it behaves somewhat similar to what I have now. My PC, whether idle or load, sounds no different in noise level. I don't want fans ramping up under load and sounding like a wind tunnel. So I am hoping someone can advise as to a good QUIET one for AMD's AM4 platform. Something that could be run at lower RPM and still keep it cool while not being expensive would be perfect. That might sound like I'm asking a lot to pick all three, but my current CPU cooler (Xigmetek HDT1283/Dark Knight or whatever it's called) from ages ago is exactly like that, so I'm hoping a modern equivalent exists?
I don't intend to be heavily overclocking but I like the option to tweak things for effeciency (mainly, a balanced power to noise ratio that works for me, hence my modest 4 GHz overclock on my current CPU which can go much higher). But, I've learned with Turbo Boost/PBO and modern CPUs being clocked by default closer to their ceilings that I may have to relearn/rethink this.
I researched a bit and it seems some Noctua around ~$100 is considered one of the best air cooling solutions. I would like to spend less if possible (say, $40 to $70 USD or so) but budget is flexible if I have to spend more to get what I want, as it will be worth it. I'd also like to NOT have to strap an overkill huge and heavy one if I don't have to.
Miscellaneous mention, but I don't care for lights or RGB or whatever; if it has it it needs to be able to be turned off.
I am ONLY interested in air cooling (lower maintanence), so no water or radiators or AIO or whatever.
Thanks in advances for any help!
