Originally Posted by
hammong
If you can afford it, Quad Channel has approximately double the raw bandwidth of Dual Channel on X79. The flip side to that is that memory bandwidth is rarely the bottleneck in common everyday tasks or gaming. If you are running a RAMDISK, large memory mathematical calculations, or running a large number of virtual machines - the Quad Channel really shows it's strength.
Hopefully, you're running a 3930K or 4930K or another hex-core CPU on that X79. The only advantage X79 has over it's Socket 1155/1150 brethren is Quad Channel, Hex Core availability, and 40 Lanes. You might as well be using all three. =)
Greg
