I recently built my custom water cooling loop, including only my cpu. I am trying to push my cpu to as far as this chip will go but i am worried about high water temps. What do you think is the max cpu temp in which I should let my cpu hit, in order to stop my water from getting to hot? Can the water get to hot? mI am on barbed fittings with hose clamps, and even without the clamps i cant get near to taking the hose off the fitting. I am worried that if the water gets hot enough, it can melt the tube a bit and maybe create a leak. The highest temp I have seen is around 36C (I know this is very low and I dont have to worry about this temp but im just saying) @ 4.622 GHz on 1.472v. So what do you guys think is the hottest a cpu should get on a water loop before causing damage and possible leakage? Thanks guys!
