What's the best way to remove a backplate off a motherboard. They seem to stick very hard.
Thank you!
Thank you!
Originally Posted by Wesker ![]() This should help! http://www.pcuser.com.au/pcuser/hs2....257141001379D6 Hope it works for you. Wesker. |
Thank you for this mini guide. I only have 2 pads down so it should not be too hard with the dryer.Originally Posted by Riou;13345526
Hair dryer on one spot for about 1 minute. Then try to pry underneath one corner of the backplate with a credit card and slide. Repeat for the other 3 ends. Don't use something metal like a razor or something like that. It might scratch the PCB.
I try not to use the adhesive on backplates any more. It is a big pain to take off.
