LinkIt took some time but Asus GTX 980 Ti Strix Gaming is finally here and you can read our review today. It's been a month since the launch of NVIDIA's GTX 980 Ti GPU and everybody was waiting for the custom cards to appear. Because of my trip to Computex I've tested the reference card just yesterday and today I've put the Asus GTX 980 Ti Strix Gaming to work. It's been an interesting comparison and I invite you to read about it.
No don't be silly its got a "GPU fortifier" to prevent sagging lol. Love the marketing names companies come up with for simple things.
this is the reviewers forum post:
1506MHz boost seems respectable to me.The new DirectCU III cooler is larger than its predecessor so we expect a lower temp on GPU and VRM. That usually means better overclocking.
Asus GTX 980 Ti Strix Gaming has a factory overclocked GPU that runs at 1317MHz (1418MHz real) while the memory works at 1800MHz (7200MHz effective). If you increase the voltage by more than +25mV, the real frequency goes to 1443MHz.
Using the new GPU Tweak II I overclocked the GPU to 1350MHz with stock voltage. Adding some voltage helped the GPU run at 1380MHz (1506MHz real) while the memory stabilized at 2050MHz (8200Mhz effective).
Now benching . Graphs coming up!
It really is. Doesn't make sense to me.
I don't think so, pretty sure reference 980ti is a 6-pin and an 8-pin instead of a pair of 8-pins
yes the reference 980 and 980TI are 6+8 . . i was going to rip on the author (a little) for taking the card apart and not talk about the voltage controller but at least there is an image:
That doesn´t appear to be the VRM controller, but the "ROG IC" instead.
Probably going to be the same like the 980 Strix. Just little heat spreaders on the VRAM under the cooler.Originally Posted by Glottis
i'm looking at pictures and not seeing how is VRAM supposed to be cooled. so far the only card that i saw does it properly is gigabyte g1, there all important components - core, vram, vrm have direct contact with main heatsink. MSI GAMING has secondary heatspreads for vram and vrm, and Asus doesn't have any cooling for vram at all?!
