1 - 6 of 6 Posts
blupupher
· Premium Member
Discussion starter · #1 ·
OK, my HTPC is pretty much all together and working (still getting all the programs and such figured out).
The only issue I have is right now my SATA drives (1 500 gig HDD for just storage and a DVD burner) are not showing up in BIOS. They are present and working fine in Windows though (XP Pro).
It is an EPoX EP-MF4-J3 AM2 MoBo, the same one I am using on my sig rig with no issues.
I installed Windows on an IDE drive before the SATA drives were installed, I tried resetting the BIOS, I have the most current BIOS for it, moved them to different plugs and such. Still not showing up. Not a real big deal since I am not doing RAID or anything, just curious if this could be a problem?
Discussion starter · #3 ·
Forgot to put that in there.
I even tried the cables that were on my sig rig and they would not show up in BIOS still (but all cables worked fine in my sig rig). Thanks though.
Are you using RAID?
Discussion starter · #5 ·
No. It is a single 500 gig HDD and a DVD drive. The IDE drive shows up fine.
Discussion starter · #6 ·
They are showing up now. I did a jumper reset when I installed my x2 4200+ and they are now there.
1 - 6 of 6 Posts
