Hey everyone! I am not sure how I missed not knowing about T Slot, but I am excited to create some builds using it and acrylic. I have multiple designs in mind for each size of build (ATX, MATX, ITX) and will be building a case for each one. Considering I will be spending a bit of cash building each case I really don't have the money to add in any elaborate water cooling parts. Maybe just one loop for the cpu at the most, but I want the build to be really clean.
For this build I will be using my current components:
CPU: 4790K
Mobo: ASUS SABERTOOTH Z97 MARK S
Ram: Corsair Vengeance 1600 16gb
PSU: Thermaltake 1,000W
GPU's: EVGA GTX 760's X 2
Any of these might be upgraded as the build goes on...
I used to build acrylic cases using an acrylic frame, like Danger Den style. Now that I have found T Slot in sizes of 20mm, 25mm, and 1" (25.4mm) and found how versatile and easy it is to use, I got excited again!
About the design:
Currently all the designs are dual chamber and the one I am starting to build today is for the ATX mobo. I wanted the design to not have any fans be mounted to any exterior panel and the fans to be attached to an interior panel. This way they can be swapped out to use different fan sizes (going from 120mm to 140mm) without having to create a whole new exterior piece of the case.
Since I will be using 25mm T Slot I can mount the exterior panels on the outside and mount fan panels on the inside, while creating a gap of 25mm between panels, the fans can mount on either side of the fan panel.
I'll let the Sketchup pics do the talking: Case size 466mm Tall x 355mm Wide x 516mm Deep
1st frame
3 frames for the case
Adding on bottom panel using 3mm black and 3mm frosted, adding on HD Cage using 6mm frosted.
Adding on SSD mount and single 5.25 mount
Adding on rear and front fan panels using 3mm acrylic. Once the fans are attached they are strong as a rock. I have mounted thick radiators with push/pull to these as well and had no strength issues.
Bottom fan panel added. Each fan panel inside the mobo chamber can be swapped out with a panel to hold 140mm fans.
Looking down from the top you can see the fans are mounted on the opposite sides of the panel.
Motherboard divider added
Back panel added (dual layer of matte black and frosted 3mm). The I/O will be made up of a combination of 3mm and 6mm acrylic to make it 12mm thick. I'm hoping the center piece will glow!
Front panel added
Looking down you can see the 25mm gap nicely fits the 25mm fan. Complete separation from mounting it to the front case panel.
Top panel added
Side windows added. I cut a gap on each widow towards the upper center for the ability to have a handle to pick up the case. It's just large enough to fit your fingers and you grasp the aluminum frame for strength.
Other colors:
140mm Fan Panels in case:
I still have a ways to go on creating all the screw holes to mount each panel and there are various ways to mount the T Slot together besides using the "L" shaped brackets. The case and design can be made using wood, metal, acrylic, pretty much anything and the T Slot is easy to configure where to drill holes......at 25mm square just make sure you're 12.5mm dead center!
I am looking forward to this build with much anticipation. Perhaps I could go all out and really get some creative water cooling done, but the wife would kill me!!!
Plus, I have other designs to build
Mini ITX Version: Micro is in the works
CPU: 4790K
About the design:
1st frame
Front panel added
Top panel added
Other colors:
