1 - 3 of 3 Posts
ASUSfreak
Discussion starter · #1 ·
So I have this AS-6202T NAS. It has 2x 4TB HDD's in RAID 1, so 4TB total.
I bought USB3.0 4TB to hook it up in the front usb port.
I can now choose to copy the NAS to the USB in 2 ways: A "1 touch backup" or an "external backup"
But either 2 options don't give me my /home folder to select for back-ing it up. I can select all folders in root, except my /home (where ALL my files are stored in ofcourse)
I'm Dutch, so the screenshot is Dutch, but I put English in it
Discussion starter · #2 ·
Well, because of the Chinese Newyear I figured it would take a while to answer my question, but they did after 10 days
So here's the answer (and it works) if you have the same quetion/problem...
Go to Access Control --> Shared Folders and edit the "User Homes" folder. Uncheck the "Disable file access to this shared folder"
Now you can backup all folders (be it in another sub folder called /admin)
So normally it would be:
/home/*
Now it's:
/user home/admin/*
( * = all subfolders in your /home folder)
/home/*
Now it's:
/user home/admin/*
Thanks for your answer. Working now.
1 - 3 of 3 Posts
