SteelSeries Qck Heavy Problem
11K views 26 replies 12 participants last post by  MaximilianKohler
#1 ·
I just bought this mousepad and while it is really nice the edges are too rough (almost like a brick). They hurt my arm. Is this normal?
#2 ·
I too had this problem when I first bought the pad. I think I either got used to it after using it for a bit or I got used to it once it got colder and I was wearing full sleeves/a sweater.
I would recommend trying it for a few days and if it still inconvences you after that, then return it.
It may be that since it's a relatively thicker pad than normal (6 mm), your wrist is at a bit of a decline and the fresh edge of the pad is digging into it.
#3 ·
I wouldn't say it's unheard of. A pro tip is letting a bit of the pad hang off your desk/table so your arm/wrist is resting on the pad itself and not the abrasive edge.
#14 ·
I would recommend against getting the goliathus control. It has little fibers that stick out and really annoy me. The mantis control had the same issue.
I'd look for a supermat in a local electronics store.
#20 ·
Originally Posted by agsz View Post
Yea i've never experienced itchy material on any QcK+ I've used. The store won't even exchange it for you when you've clearly, barely used the mousepad?
Originally Posted by AnimalK View Post
I've been using a Qck Heavy since December without any issue. Mine is very soft/pliable and doesn't irritate my skin.
You might have a defective pad.
Could you be having an allergic reaction? Could it be your skin is too dry?
I used wipes to clean the cloth of the mousepad, it's good now. The edges are still rough though.
#21 ·
You could put it in the wash with your clothes too.
#25 ·
I find it really good. I use it with Avior 7000 and it slides really good, not too easy not too hard. I had a cheaper A4Tech X7-300MP or something like that and it was heavier and offered more resistance and also absorbed sweat like crazy. I have the Qck+ for 3-4 weeks and it's the same as new. I like this one better. Also it's pretty thin which I prefer over the heavy version that is twice the depth. So far I like it we'll see how long will last
#26 ·
Originally Posted by GenoyTex View Post
I'm thinking of buying the Qck+ from another store, a more trustable one. Is the mousepad good? How do you find it? I'm not going to buy the Razer Goliathus because MaximilianKohler said that I shouldn't. Kinda confused here
at least you shouldn't buy the goliathus control if you somewhat liked the mousing on the qck heavy, because the gol. control has a completly different glide.
the goliathus speed it what you want then.
