Well, in nothing i've tried am I able to read temperatures for my cpu, I can read the cpu core temps, but not the overall cpu temp. Also I can't read the volts for everything or adjust fan speeds.
A while back when I got a nifty little Vantec Tornado fan, my brother thought he could make the fan control for the fan work (for some reason it wasn't and still isn't resolved) and he switched a pin in the connector to a different hole and plugged it in. Almost immediately the fan speed went down, and then it started going down more and I smelled burned electronics and flipped the switch on the power strip shutting down everything.
I unplugged the fan and let everything air out (burned electronics smell awful
) and tried everything and everything was working properly and no noticeable damage and such.
Recently, All voltages for the motherboard read 0.00, it doesn't even show any fans running (they're definitely on and working), and the temps (with the exception of core temps which read fine) read -249.7c. As much as I wish that was the real temps, I know it is not so and am stuck here templess
Any ideas on what is wrong and what I should do about it?
I'll upload some overdrive screens to show you
