SourceDell has long marketed an impressive line of monitors for every conceivable use, but only recently has it come out with true gaming displays. The S-series is billed as gaming and multimedia appropriate, but only a couple of models have sufficient cred for the enthusiast crowd.
At least for the foreseeable future.Originally Posted by Peanuts4
Another TN... Refresh rate really isn't selling me on another TN monitor after my last Dell G-Sync experience. But if you want minimal Quality control but can get searingly bright there ya go. Are TNs ever going away or are they just that cheap to produce we're stuck with them.
Dell has much less quality control problems with their g-sync monitor than others.Originally Posted by Peanuts4
Yeah, they could've at least cover it with glossy coating, but no, we can't have nice things.Originally Posted by Peanuts4
I think we'd all like but that's like waiting for OLED. IPS is clearly the best all-rounder.
I've never seen the appeal either.Originally Posted by wolfej
I still don't get the appeal for IPS. I would much rather have higher quality VA monitors. I've had multiple IPS monitors and they were just disappointing after all the claims of how good their picture quality would be.
That was after attempting to calibrate them, and then paying someone to calibrate them. Meh.
Why is IPS "clearly" the best all-rounder?
Its only obvious weakness seems to be lack of high contrast. VA is a compromise all situations.
I'm not sure what you're arguing. Being in the middle is the definition of what an "all-round" choice is.
Hyperbolic. Modern IPS and VA panel pixel response times are essentially the same. Your complaint about blending is not something that I've ever heard about nor observed.Originally Posted by Smanci
If we ignore all the other issues, VA's really slow response times are a big con. High contrast is a nice thing to have but the benefit is questionable if pixel transition times are slow, and in the centre of the monitor, lighter shades blend into black and form a dark lump of no detail.
Not for the slow transitions, even the best VA panels have their worst transitions take well over 10ms. For example the new VA Acer Predator Z271 has response times over 10ms for 0 to 255, 0 to 200, 0 to 150, and 50 to 0, with a gray to grey average of 6.6ms at 144Hz and the worst transition at 15.3ms. It also has some overshooting due to needing aggressive overdrive.
