Has anyone tried these new sheets yet?
I thought the KryoSheet was graphene? Or are we talking about two different things?How long does liquid metal last anyway? Not long enough if you don't buy the latest CPU every season. 5c loss.
I did not dam it off around the APU.I have been using PTM7950 for a while now on PC components, also on my Steam Deck. I have a BUNCH of 80mmx80mm sheets. One can do at least a 3080 ti die, intel IHS, and a few Decks with a bunch left over for smaller stuff.
Should drop temps about 6c by itself vs factory Valve paste, and also drop fan speed about 400rpm's. I also have a larger heatsink and jsaux backplate with the metal cooling plate. Overall temps are down about 16c and fan speeds about 1200rpm, mine was thermal throttling and the fan annoyed me. I also used TG-PP10 under the Poseidons' larger monoblock heatsink which covers some IC's and the RAM, tested with a thermal probe before/after, and RAM temps are lower as well. I would imagine Liquid Metal performs excellent, and i assume you dammed it off around the APU. Only downside is the jsaux backplate aluminum heatsink area gets up to 63°c but thats with APU pulling a lot more power as well...
Give it a whirl, its great for stuff that gets drug about.
