I have been trying to get information regarding the Thermaltake Commander FP Hub's performance and effectiveness, but I cant seem to find any reviews or information on this product:
http://www.thermaltake.com/products-model.aspx?id=C_00002702
Here is what I am trying to do with this product, or indeed any product:
I am trying to control ALL of my 4-Pin PWM fans all from one temperature monitoring source. The main objective is to use the single PWM 4-Pin Motherboard header I have to control all my case fans along with my CPU Cooler fans (9 total, 7 X 140mm and 2 X 120mm), to all operate at the same speeds at all times, to create a very efficent system that is dead silent under light loads such as browsing, but then ramps up to cool the system under heavier loads.
I do only have one 4-Pin Mobo header, and 9 X 4-Pin PWM fans to control, and even if that changes in the future, I would like the idea of all fans controlled by a single temp monitor. However, I do realize a single PWM header does not have the power to control 9 fans simultaniously, this is where I am hoping the Commander FP's SATA main power comes into play. Im hoping the main Voltage, Amperage, and Wattage supply comes from this SATA power to keep from blowing out my MoBo's PWM header.
Any ideas on this theroy? Any alternative products you would like to suggest that dont break the bank (under $40)?
