Hi!
Broke some tiny "resistors" off my Viper Steels RAM modules.
After the breaking off of said resistors the RAM could not post.
Investigating if the missing resistors were the cause of the non post scenario I bridged the pads with a fine piece of wire.
After doing this the RAM can post.
My question is as follows.
When I removed said resistor and measure the resistance I get a reading of 15.2 ohms.
When I test if the resistor is a short with my multimeter it indicates with a beep that it is a short.
But when I Google as to what is accepted as a short the general value is agreed to be between 1 to 2 ohms.
So back to my RAM and resistor.
Firstly, seeing that these resistors measure 15.2 ohms which is considerably higher then what is considered a short, why does my multimeter beep when I measure across the resistor? I am guessing its because it is a low quality multimeter ?
Secondly, seeing that the RAM works by simply bridging the pads, why are there many 15.2 ohm resistor doing this job that could have been done with a fine piece of wire ?
