System:
CPU i7-4930k
Motherboard: Asus Rampage IV Black Edition
https://dlcdnets.asus.com/pub/ASUS/...pub/ASUS/mb/LGA2011/RAMPAGE_IV_BLACK_EDITION/E8670_Rampage_IV_Black_Edition.pdf
Air cooled (good temps)
G.Skill DDR3 RAM 32GB
MSI Gaming X GTX 1080 with stock cooler
Error(s):
1. "USB Device Over Current Status Detected!"
- unplugged all usb devices from all the ports, unplugged the single drive (SSD), unplugged DVD drive, unplugged the Asus system monitoring addon thing, literally everything that has to do with USB or storage--even mouse and keyboard from the rear ports and the front panel connectors (I can boot using buttons on the motherboard itself). The error is not going away.
I've swapped between 2 different BIOS set-ups (there's a BIOS toggle on the motherboard).
The last post code shown on the motherboard until shut down is "55" (which seems like a RAM issue, but all 32GB are detected fine, and the RAM had no issues up until now in this very system).
Is there anything else I can check to help troubleshoot this?
2. CPU fan error. I have 2 CPU cooler fans connected from the new Be Quiet Dark Rock Pro 4 cooler: one in the CPU fan socket--spinning fine, and the other in the supplemental CPU fan socket--also spinning fine. I've tried resetting CMOS, still fan error. I was reading that maybe it's a fan RPM/low voltage issue for the fans, so that's a secondary issue for me at the moment. I can't get into the BIOS to change fan settings because of error #1.
Do these in combination point to a defective motherboard? It worked reasonably well until I took everything apart recently to remove all water cooling and switch to air. Everything is clean, nothing was spilled on, everything was touched really carefully--by far not my first system.
CPU i7-4930k
Error(s):
