1 - 20 of 26 Posts
HQToast
Discussion starter · #1 ·
I want to buy a R9 290x with the NZXT Kraken G10. This is the first time i'm using something with water cooling. But with the Kraken G10 the VRAM and various other components are not cooled very well. I thought about adding VRAM heatsinks to make it i little bit better. But what if i want to take them off again? I mean they have some thermal pasty glue on them to stick to the surface applied. Will i rip out the Modules by replacing them?
Does anyone have experiences with that kind of cooling?
Heatsinks: http://www.newegg.com/Product/Product.aspx?Item=N82E16835118220
Cooler: http://www.nzxt.com/product/detail/138-kraken-g10-gpu-bracket.html:)
Card: http://www.asus.com/Graphics_Cards/R9290X4GD5/
Also.. I know... I'm a noob... but i will learn... please don't hit me...
Hi,
- get cooper, not aluminium heatsinks. If you have a good budget get Enzotech heatsinks.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835708012 ( i don't know if they are to tall for g10, you can check)
If you need shorter ones take these
http://www.amazon.com/Cosmos-Copper-Cooling-Heatsinks-cooler/dp/B00637X42A/ref=sr_1_1?ie=UTF8&qid=1400951839&sr=8-1&keywords=copper+heatsinks
If you're not going to change dissipation and nzxt g10 is final cooler you should use some artic silver thermal adhesive for applying heatsinks ( better heat transfer).
Discussion starter · #3 ·
Agreed. Copper might be a better choice. The thing i worry about are the thermal pads. All those heatsinks seem to have them preinstalled. That's not a bad thing, but will i be able to remove them if i need to?
I plan to use the G10 as a final cooling decision, but if the card breaks it would be nice to put the stock cooler back on and send it back to repair. I know i don't really have a guarantee after removing the stock cooler, but ASUS doesn't seem to care about that so much...
I'm going to check the height for the sinks. A friend has the G10 installed so it shouldn't be a problem to get that information.
My budget is kinda high. I'm building a new computer with a budget of around 2300€ (~3000$).
I'm italian so euros is ok !
If you are worried about guarantee don't use artic silver. take a look at this review http://www.tomshardware.com/reviews/thermal-paste-performance-benchmark,3616-5.html
Remember you need thermal adhesive not thermal paste/pads for vram heatsinks.
Please when you get infos about heatsink max height write them here. I'm interested too.
bye
Discussion starter · #9 ·
Sounds good. So they do stick to it without problem but you can still remove them without ripping the whole chip out.
Oh man 33€ just for heatsinks ^^ I wonder if there is a already made closed loop card that i could get for that price. (~600€)
Discussion starter · #11 ·
There is not much more to say. I want to use a r9 290x (Link above) with the Kraken G10. The cooler will be a NZXT X40. I've red much about vram being not so happy without the extra cooling. I mean there is a fan blowing air kinda in that direction, but it seems like some extra cooling would be good.
check this out . . .
http://www.overclock.net/t/1478544/the-devil-inside-a-gaming-htpc-for-my-wife-3770k-corsair-250d-powercolor-r9-270x-devil-edition/20#post_22214255
Discussion starter · #14 ·
That would be a way to do it yes. But i would be happier if i can be sure that i will not rip out my chips while removing them. But thanks for the info
Now i know that the copper sinks mentioned above will be able to get replaced.
I'll probably buy a pack of them and test 1 heatsink on another older PC.
If someone else had experiences with other brands of heatsinks i would be happy to hear them
So which do you think will be a better heatsink for my GPU VRAM? The copper ones I have are smaller than the black Alu ones. And they also do not completely cover the entire DRAM chip.
Copper can be quite a bit better than aluminum for something like this, and even a flat plate of it can help, even if it's no bigger than the chip package (I have no idea how).
Don't remove heatsinks by prying them off. Instead take a razor and slice through the adhesive. If you don't have double-stick tape, use silicone rubber sealant, which tends to work better than tape because it can be made thinner. You don't need special thermal silicone sealant, just the ordinary stuff sold everywhere.
1 - 20 of 26 Posts
