1 - 5 of 5 Posts
GPU upgrades for AIO PCs are severely limited due to poor heat dissipation. The specs info says you're using a GeForce GT520. As I'm sure alot of planning going into picking the best GPU for an AIO... Acer picked the GT520, so the best option would be to replace it for another GeForce GT520.
If you want a different card, my only suggestion would be to scale down. The absolute highest you should use for an AIO is the model it already includes.
Discussion starter · #4 ·
I have acer aSPIRE z 3771
http://www.acer.co.nz/ac/en/NZ/content/model/PW.SHP02.006
i haVE window home 7 premium trial version right now and now every thing is working fine but the nvedia grapics card.
when i play a movie the pixels burst. and when i go to nvidea control panel it comes to YOU ARE NOT CURRENTLY USING A DISPLAY ATTACHED TO NVIDEA GPU.
when i go to acer website and download nvidea grapics card and try to install them it gives me an error YOU MUST INSTALL INTEL DRIVER FIRST and when i try to install intel drivers downloaded from acer website for my computer it gives an error YOU COMPUTER DOES NOT MATCH THE MINIMUM REQUIREMENT.
now i have installed n videa drivers directly from nvidea website but the movies dont work good.
also in my device manager my pci device is not installed i dont know how to install it. Please help
1 - 5 of 5 Posts
