Wiggling 24 pin power cable turns on/off computer?
1 reading
26K views 10 replies 6 participants last post by  Defunctronin
#1 ·
Yesterday I turned on my computer to find that the running lights would turn on but the computer wouldn't post. It's been in fine working shape since I built it!
I switched power supplies and still had trouble getting it to boot/post. With this temporary power supply, if I pressed the power button, it wouldn't do anything. But if I touched the wires leading to the 24 pin and moved them around a bit, I could get the computer to boot so long as I held them in place.
It looks like the problem is the motherboard 24 pin connector, but this is so strange to me. Has anyone had this problem before? Is my diagnosis correct? (With the old power supply, the power LED on the mobo flickers--but not blinks--when it should be a solid consistent color.)
Edit: For the sake of google search indexing, this is a ASUS M4A87TD EVO.
#2 ·
Edit: stoned on benedryl, sorry. So, it sounds like it's the motherboard's 24 pin making crappy contact then. Man that is weird. Can you wiggle any pins of the motherboard within the housing? Cold solder joint possibly?
#5 ·
It won't turn on if it I don't wiggle it and hold it in place. With the original PSU, wiggling has no effect.
Actually, the first few times with both power supplies, I got it to turn on for a few seconds (only sometimes it would post). And with the second power supply, I got it to post and run windows for a few minutes until it shut down sporadically.
It looks like these ASUS motherboards have this "EPU" power management deal.
#7 ·
If it's the motherboard and it's still under warranty, rma it.
If it's the motherboard and it's not under warranty... you might be able to get it repaired, but I wasn't able to find any literature about replacing the connector that's located on the motherboard, but I bet somebody could do it.
If it's the power supply and it's still under warranty, rma it.
I doubt it's the power supply connector end, but if it is, and you have basic sleeving tools, (molex tool, heat shrink, lighter/heatgun) you should be able to safely take the connector off and see what the problem is. You can also order replacement pins and crimping tools from performance pcs or frozen cpu if you need to fix it..
#10 ·
Check the contacts on the 24pin plug from your PSU. If one of the contacts get loose it can cause this to happen. Look at the contact side of your 24 pin plug, if there are any of the connectors that look to be spread apart more than others get a small screwdriver and push them closed.
I had this same thing happen with a PSU. I had been using a piece of short wire to ground the green and one of the black wires on the 24 pin to turn the PSU on without having it hooked up. After turning it on/off a few times like this the contacts spread open some from having the wire shoved inside there. The next time I hooked the PSU up to a MB it was doing exactly what you are describing because the 2 connectors I grounded so that I could test the PSU were not making good contact.
