Will the Japanese PS3 work in the UK?
3.7K views 19 replies 13 participants last post by  c00lkatz
#1 ·
As far as I know it wil because games are region free, but the question is will my TV support it?
Also, I takeit that if you have a UK power lead, for the PSU on the PS3, you can just use that as its the same socket?
#2 ·
what tv do you have mate? if its a flat panel with vga/dvi/hdmi input on the back, then any ps3/games console will work
#4 ·
Are you 100% sure?
The seller im purchasing it from states that its the same power equirements and also supplies the UK power cable.
I take it US NTSC will work through HDMI aswell then?
I have a flat panal LCD TV and will be playing thorugh HDMI
#10 ·
YEs...IF you could get a step-down transformer. A chinese PS3 would work, as they're 230v. I dunno the workings of the PS3 - Is it a power brick? if so just swap it out for a uk one regardless of voltage.
#13 ·
I have an online friend with a Japanese PS3 and he says he can only play JP games, though that's contradictive to what you guys say...
On the other hand, I have a rl friend with an Israeli PS3 that imports games from Japan.
As for NTSC/PAL, don't worry about it. It really doesn't matter... everything works with everything.
#14 ·
The ps3 games are region free, but Japanese games will still be in Japanese, so could be hard to understand if you only speak english
As for the power, it really depends on the PSU in the ps3. If it can auto-switch, then you would just need to get any power cable that works in your country, like the one you plug in the back of your PC, and you'll be good to go (my laptop was like that, I went to germany and just had to get the end power cable and it worked fine).
#16 ·
Originally Posted by Mootsfox View Post
If the games are region free, why is there a little 1 and a globe on the side of every US game?
Well I guess they show the region anyway, im pretty sure they are region free.
The numbers on the back are probably to track where there made, plus the majority of them will be sold in that country anyway.
Ive read that PS3's are dual volted or something along those lines, a 5A kettle adaptor works fine with my friends, and even the pc cables that come with psu's work according to many sources on the net.
#17 ·
Just check on the back where the power lead goes in, it should say something like 110-240V or something, as long as its that, you are good. otherwise you need a stepdown transformer.
#18 ·
Won't Pal/Ntsc also be a consideration?
#20 ·
Originally Posted by rRav3n
or just go and buy a uk ps3 from a store or ebay why have all the hassle related to making sure you don't blow the thing up ...
Seriously, unless you're saving A LOT of money, it doesn't seem worth it to me.
