Originally Posted by
l88bastar
1080p
2017
1080p
2017
1080p
2017
1080p at 240hz and 8 bit color requires about 12Gb/s which is above hdmi 1.4a.
1440p at the same setup, requires about 21.2Gb/s, which is above DP 1.2 and HDMI 2.0 and almost reach DP 1.3.
4K at the same setup, requires 47.7Gb/s, which is above DP 1.3/1.4, and hits the ceiling of HDMI 2.1 which only now announced, and it will require new cables, and new GPUs which aren't even out yet to test.
2017 claims is all nice and dandy, but you can't make a monitor a large part of your market can't even use.
Let alone making a high resolution panel that can handle such density and performance consistently which could be technically too expensive to make.
All of AMD's lineup except the new mid and low 400 series cards for example, don't have support for such a monitor if it was above 1080p, and even nvidia's previous gen cards are locked out of it.
