10850 K & 10900 K temps
8.8K views 12 replies 8 participants last post by  fra z
#1 ·
Hi,
I've not used either of these yet (busy elsewhere) I've read the temps run really hot @ 4800 Mhz all cores.
When I do use these it'll be with a good air cooler or 360 mm CLC.
One user reported 90 C + all cores @ 4800 Mhz.
When I do OC I don't like temps too high so what is the best all core boost where the temps are the best such as 70 C - 75 C all cores?
Delids are not possible on 10th gen are they?.
If I look back at previous OC's such as
Xeon E5 1680 V2 @ 4.2 Ghz / 4.3 Ghz
i7 7700K @ 4.9 Ghz (delid) good temps after delid but awful before
Would a 10850 K @ 4.6 Ghz all cores work with good temps circa 70 C?
Any info helpful as this will prepare me for an OC and what to expect - :)
#2 ·
I've got a 10850K, ASRock Z490 Phantom Gaming-ITX/TB3, and NH-D15 with NT-H1 TIM. I can't remember exactly what my settings are, but I'm using stock voltage settings and ASRock follows Intel's reference spec here. I think I switched on multicore enhancement and increased the power limit to 200W sustained.
It'll run at 4.4GHz on all cores indefinitely. Temperature is around 75°C. If you have a good liquid cooler and/or use something like liquid metal and/or delid, then 4.6GHz on all cores is plausible.
Those last few hundred megahertz really hurt though. I need to increase the power limit by 100W to hit 4.8GHz and the cooler just can't handle it. 10% more performance costing 50% more power is pretty typical though once you get near the chip's limits.
#3 ·
depends on the silicon. My 10850K needed 1.3v+ for 4.9 and my 10900K only needs 1.26v for 5.1.
yes, you can delid 10th gen.
4.6 is a 200 mhz underclock on the 10850K so I can't imagine you not being able to cool it with an AIO.
#4 ·
Hello,
Great ! - Some good feedback !
On Kaby Lake 7700 K I got a big shock before a delid - and "The Pook" here informed that basically with 6th / 7th gen i7 a delid is needed - Which I did on a 6700 K before drowning it accidentally in LM (big mistake - because the "nozzle" wasn't put on the end of the Thermal Grizzly - But I learned fast because it was important.
Then a 7700 K was delidded - and after experimenting with thermal / paste then LM - A great OC was achieved on 7700 K @ 4.9 Ghz with good temps that made me feel happy.
OK, I've read that on 9900 K it is a lot more involving to delid maybe because of a solder that is difficult to remove - But this is where a solder "dissolver" is needed (which I have) - Is this correct?
OK moving onto 10850 K / 10900 K - Will it be the same "hard solder" that would need removing with "solder dissolver" - And if so, if this was done as per the 7700 K, would the temperature results be similar ish ? - OK, 10 cores is more difficult to cool than 4 right? - But would there be a result where the chip would be 20 C cooler (maybe 15 C) just like the 7700 K was?
#5 ·
For any type of LM squeezing, I recommend NEVER plunging the plunger, not even a little bit.
What I do is twist it left and right slowly while applying a minimum amount of pressure inwards. That way the twisting creates its own pressure and then the LM will slowly start to form a nice small ball, then you just release the ball on the surface and repeat if you need more.
I haven't had a LM accident since doing that, and I even re-use the kryonaut plunger with homemade Galinstan, so I can use the tip to apply the LM.
#6 ·
Hi, Falkenstyne,
I took more care afterwards when the mistake was understood - Then the tip was used and away from the CPU - The little ball you refer to is known as a "euctectic" which is very scientific and I must admit I needed to look it up when this was read about - But the whole process of OC'ing is scientific in nature whether we realise it or not - :)
#7 ·
With the proper delid tool it isn't hard. Rockitcools kit come with solder removal stuff. It is a good idea to heat up the IHS first with a hairdryer or heat gun to loosen it up a bit first tho. Makes it much easier.
A good AIO can handle a 10900K at 5.1-5.2 after a delid just fine if it isn't too bad of a sample. Up to 1.35v is manageable on a EVGA CLC360 and H115i Platinum. Expect 90+ on AVX stress tests anyway but gaming holds up fine.
Mine is terrible, it needs 1.39v for 5.2 all core and direct die liquid metal with a custom loop it runs low 70's in gaming and touches low 80's in for example Cinebench R23 and 3DMark Time Spy / Port Royal.
Reactions: fra z
#10 ·
Hi,
All very good input - Thanks - :)
I'm not hell bent on 5.0 Ghz - On 7700 K it was good @ 4.9 Ghz - So anything from 4.6 Ghz +/- will be fine.
I do have Corsair H150i and have used air coolers - such as Noctura NH-D15 or Dark Rock Pro 4 - etc.......
Is there much difference between a 240 mm AIO vs 360 mm AIO ? - Thanks
#13 ·
Hi,
Great replies and helpful - Thanks
I wouldn't go for a top of the tops OC and settle for just a little less but have an easier time in managing the OC! - Be-Quiet Dark Rock Pro 4 is a good air cooler too - Air is better for 24/7 if the temps are good enough and easy enough to manage
