120MM Fan Hole Size?
14K views 5 replies 6 participants last post by  meticadpa
#1 ·
Hey
Ok im going to mod my case and but i am unsure what size the screw holes are for a 120mm fan
If nay one could assist i would appreciate it
Thank you very much
#2 ·
Originally Posted by XX-Sunny-XX View Post
Hey
Thank you very much
That depends...what is the screw hole size of your fan?
Generally speaking, however, they are usually 3mm.
#3 ·
As long as you aren't tapping threads, it doesn't really matter... whatever fits.
#5 ·
use screws and nuts that pass the fan frame instead of the silly self-tap screws that come with the fans. get 1.25" screws (6-32 thread and matching nut will work) for a 25mm thick fan. for 38mm youll need a longer screw (go measure)
#6 ·
This.
But he's British, so get a 4mm screw.
