Originally Posted by tweaker123
k, i mean the pixels and such. or can AAx and AF change that.
not color, contrast, brightness etc.
1600 is exactly 11.11_% better. And no, the illusion of more pixels cannot be created with AA. All you're gonna get is answers based on pure opinion, why not set your monitor up for those two resolutions and see for yourself?
well if you have monitor which has higher resolution, everything will be sharper and clearer
if you lower the resolution on that same monitor below it's native resolution it will get a little bit blurred because of the lower resolution (acting like you turned on some anti aliasing)
if i get what you wanted to know...
Originally Posted by cs_maan
Quality depends on monitor like Kenny said, physical difference is only that the 1600x900 monitor will be wider (obviously).
If anything you'll get wider FOV in FPS games, and again obviously more pixels from one side to the other.
Different games treat 16:9 vs 16:10 differently. Some give 16:9 a wider fov, some give them the same horizontal fov, and give 16:10 more vertical res. Resolution doesn't matter.
Originally Posted by ImmortalKenny
The resolution has nothing to do with AA or AF.
A 1600x900 monitor will display 160 more pixels than a 1440x900 monitor...that's it.
would it be worth upgrading from 1440x900 or 1600x900?
i returned my dell 24'. and right now im using my 19 inch. i was thinking about getting a 20 inch acer that has 1600x900. would it be worth it? or should i just stick with my 19'
going from 19 inch to 20inch... and few more pixels isn't really an upgrade... waste of money is what i call it. Your next monitor purchase... I'd recommend a 120hz 32+ inch 1080p TV :] other than that, any 24inch would satisfy as an "upgrade" in my opinion.
one more question.
is 1600x900 more demanding on games than 1440x900?
Naturally. It shouldn't be that much more demanding, but nonetheless, you won't get exactly the same performance you would at 1440x900.
Related Threads
Overclock.net
posts
28M
members
563K
Since
2004
The premier forum for overclocking experts and enthusiasts. Discuss hardware optimization, custom builds, benchmarking, cooling solutions, and pushing the boundaries of computing performance. From beginner guides to extreme overclocking, join our technical community to master system tuning.
