2.1 Speakers and Sound Blaster Z + headphones / amp?
11K views 3 replies 3 participants last post by  Tiihokatti
#1 ·
So I've always used either headphones or 5.1 speakers on my comp so I'm curious about something. I have a Sound Blaster Z and if I wanted to switch to 2.1 speakers what socket on the sound blaster would I use? With 5.1 it's obvious I would use the 3 designated ports + the headphone port for my headphones. But with 2.1 speakers would I have to use the Headphone Socket + Sub for the 2.1 speakers and no headphones?
Are there 2.1 speakers with a powered headphone amp built in?
#2 ·
Only the headphone output is powered. Moving from there toward the optical end of the card are your Front L/R line out, Rear L/R line out, and center/sub line out. All are passive.
Assuming you have the typical 2.1 package with a powered subwoofer that also feeds the L/R main channels, you run a 3.5 mm cable from the Front L/R main on the Z to the sub, and the L/R fronts feed from the sub. (sub and rear ports not used)
If you have separate, non-matched sub and main speakers, it's runs just like the label. Your L/R mains will run on a 3.5mm line out from the front L/R port and the sub will run on a line out from the sub port. (rear port not used)
If your sub isn't powered, your going to need an in-line amplifier or another plan.
#4 ·
Originally Posted by Peanuts4 View Post
So decided to go with a couple bookshelf speakers. The question now is if I order an amp what socket do I use for that? Also I'm considering 2 books shelf speakers and if I decide to ad a sub later what would a good amp be to do that?
Speaker amplifier, right?
You just use the front speaker port of your SBZ.
