I am looking for the best 280mm radiator 60mm thick or less. There are so many 360mm rad roundups but nobody seems to care for the 280mm form factor.
SOURCE
This review has the HWL Nemesis 280GTX on top, but does not compare all 280mm rads. I know the phobya g-changer 280 is pretty good too but I do not know how it compares.
I am space limited so a single 280 rad is what I will use for a Ryzen 1600x and GTX 1080. I do not require silent operation but prefer to only buy a rad once, so I want to find the best I can. Not sure if I can fit a push/pull config with a 60mm rad, but I know I can get a 60mm with push.
What other 280mm rads may out-perform the Nemesis GTX?
Thanks!
SOURCE
Thanks!
