384kbps... Is it enough?
11K views 26 replies 23 participants last post by  karcus01
#1 ·
I am looking to get an adsl line installed so i can play my games online.
I am a little tight on money and only have enough money at the moment for a 384kbps line. Will this be fast enough or should i try and convince my parents to give me extra money for a 512kbps line.
The games i wanna play are mostly FPS's like call of duty and battlefield.
#5 ·
i use a 6mb , totally worth it.
#8 ·
Try 512, is way better it wont lag, no delay , faster connection, but if you cant afford it then go for the 384...
#11 ·
Originally Posted by LimeX View Post
i have 10 mb net
i play cod2, cod4....
when i got 1 mb was the same... ping is the same
so is the same iff u have 364 or 512... with 512 u will dl maps and mods faster
for the ping or lag is the same
this man speaks the truth. You want a connection with the lowest latency rather than the highest bandwidth. Having a high bandwidth doesn't matter much in online games. I have had two 10 mb/s connections and the difference in lag is pretty awesome on the one that consistently has 10 ms pings
#15 ·
Originally Posted by L3gacy View Post
companies usually advertise its 512 or 384 or whatever but to find you're true speed divide it by 10 and that is the real speed you get, I would reccomend 512 though as it is the minimum for many games now 384 is good for small matches and 512 medium size matches
You've got it all wrong. The only time you divide anything is when you're trying to convert from MegaBITS to MegaBYTES. Companies advertise their speeds in BITS. To get your speed in BYTES you divide the BITS by 8, not 10. If you had a connection of 8megabits per second, your download would be 1 megabyte per second (ideally).
Not trying to be an ass but just trying clear up misinformation.
384k, eh? I take my cable connection for granted lol
#16 ·
That's technically correct but it is more realistic to divide by 10 instead of 8, as almost always you're going to have some sort of overhead with the connection; this way you can take that factor into account. Of course, if you have super-awesome fiber-to-the-home internet, you may not get the overhead.
#17 ·
My connection must be awesome then
#21 ·
the download wont really affect your ping as much as the upload and you probly get same upload with both speeds.
#22 ·
24Mb, waaay more than what i need just for gaming. For a fun time id be looking for something bigger than 384....depends on the game. You have to remember that sometimes you will be downloading files from the server, not necessarily just communicating with it. Lag is pretty much ping dependent after 1mb for anything, I have 1mb upload so this is the limiting factor.
#23 ·
Update: My dad might also get adsl (he plays games as well). So we have might go half half on it. If we do this we will go for a 4mbps uncapped line. Does this mean if we both use it at the same time we will each get about 2mbps. And how much will it cost to buy the equipment (router etc.).
#24 ·
There's a sale on Newegg for a 802.11n + 4x100Mb/s residential gateway + adapter.
4Mbps is total.... you don't want to split it. Let the router determine packet priority.
#26 ·
ADSL and gaming? One word for that : FASTPATH! You can have 20 milliong gagillion megs but if you don't have good peering you can show off with that connection.... on paper.
This will answer the person who said that gaming quality is related to speed. Correction, that is only one factor!
