Ok Guys you saw that cheap cardboard thingy I made Here. Now im gonna try make a professional looking one
Heres my plan (Ill try sketch it out later)
Ok About the size of an average phase change unit, about 7" High
6 120mm fan holes (3 on each side)
Body made out of clear black acrylic and the bottom 1.5" made out of Crystal clear acrylic (this will be the res)
Pump situated near the back pumping into the radiator which will go into the blocks then into the res)
I will be using a D5 pump and my BIP360 like in the waterbox I already made
SO, Do you think its possible ?? Will I need metal retention brackets to keep it from breaking ?
