Got this air bubble in my cpu block. Have tryd to tilt, shake, and letting my pc lay vertically. Cant get it out. Will the air in the cpu block have any effect on my cooling ?
Motherboard: Asus Maximus X HeroOriginally Posted by 033Y5
it would be helpful to know what parts your using and if you could you add your pc to your sig
http://www.overclock.net/t/1258253/how-to-put-your-rig-in-your-sig/0_30
what parts are you using?
The one to the left is out
When i run my 8700K at stock i have like 30 idle, but spikes to 40-50 ish. And ingame i have around 40-50. Stresstest will rise it til 70 ish.Originally Posted by Iceman2733
What are your temps like? With bubbles like that they are hard to get out, you can try to turn the pump to its highest setting and turn it on and off a few times quickly. Sometimes with bubbles like that you just don't worry about them as long as the temps are OK. They will eventually work there way out as the fluid heats up and cools down.
guess it depends on your ambient temps what are they like. If that was me, would fuss with it for a bit buy moving the PC about see if can't get rid of the bubble.Originally Posted by Para69
CPU: Intel i7-8700K
Waterloop: EK
Picture of the whole loop
got the same temp with OC to 5GHz.
Stresstest will rise the temp to 80 ish
