Hey guys.
I am in need of some advice. I have about 70mm Clearance on the Phantek Enthoo Primo case on the top before it starts messing with the motherboard. There is additional space for the top fans so top fans are a non issue.
So I was wondering if anyone can tell me if I should go with XT45 with push pull setup of UT60 with push only setup. Both are 480mm rads.
Thanks
Thanks
