Hi!
The dilema of using a Artisan Raiden (both XSOFT and MID): most amazing feeling ever, the dynamic friction is the one i want (super-fast with EASE during movement) and the static friction is just flawless to my taste after being worn down a bit. Now the problem occurs [sometimes] when moving non-linearly such as circular movements. In 2D games the cursor flies into a corner, in 3D games it instantly rotates somewhere between 150° to 360° or it spins like a spinbot (if i stop moving my mouse the same instance the spinning start - it wont stop spinning).
It appears in different degrees depending on what mouse im using: G403 (3366) spins slightly more often than my EC2-A (3310). Using a different mouse doesnt seem to be the solution.
Both of my Raidens are pretty worn. Dynamic friction isnt affected by the wear but the static is. The more worn out it got the more i liked it [the increase in static friction = more force required to get the mouse moving, but stopping becomes easier aswell]. For people that have used Raiden, you know its increadibly slippery at the start.
The problem with QCK is that its increadibly slow while moving [dynamic friction] and fairly low static friction - its almost the complete opposite of what i want.
Now im looking for an alternative mousepad. Any ideas or suggestions? Thanks in advance.
