I need to compress some video projects to around 7gb so they would fit in a dual layer dvd.
get avisynth and install it, then get megui, install that. encode video and choose your bitrate or file size.
I tried version 0.9.5 its the version that has target file size, then I left my pc overnight to do some tests.
Basically I have a 10GB H.264 video that I made with after effects.
thanks, i found out that only the older version of handbrake had that option.Originally Posted by Shadow11377
That's easy to do.
Go into the video tab, and under Quality select Target Size(MB) and enter the amount you want. It's not perfectly accurate, so go just a little bit lower if you're trying to fit it on a DVD. 7GB could be a few megabytes off.
Alternatively, you could look at the kbps of the 10GB file and do math to find out how much your video would be in kbps if it were 7GB, then select that option and enter that number.
thank you shadow !! i am literally thanking you after 2 years !! this was useful !! smile.gif cheers !Originally Posted by Shadow11377
See: http://en.wikipedia.org/wiki/Variable_bitrate#Multi-pass_encoding_and_single-pass_encoding
It's not really needed.
And that sucks, I'm glad I don't ever try updating Handbrake. Losing features is not something I'd like.
My Handbrake Version is 0.9.5 (2001010300) if you're interested in getting mine.
