Anyone know of a sound card with HDMI output for HD audio? Audio streams like atmos, dts master etc?
And yes I know I can use the HDMI output of my video card for this, but I want a separate output stream for it. Since I use a 4k hdr monitor and it doesn't have speakers and also doesn't have ARC, I need another solution. I have HD audio denon receiver and speakers, currently using optical out.
I know, i can use another HDMI output on my video card to the receiver, but the problem is, if the video card doesn't detect a monitor it won't output sound. Seems like some limitation of HDMI where it won't put sound unless it can also put video, which is stupid.
Another issue is if i turn on the receiver so it acts as a passthrough for a monitor, the hdmi will work but then it sees it as a monitor and puts a display on it, and then of course it doesn't work with DRM because it doesn't see the hardware encryption stuff and I can't watch any copyright material or netflix etc unless i unplug it.
So the solution is, a sound card with hdmi sound output, but i can't find one anywhere. Or a device that will trick the hdmi into thinking it's connected to a display when it isn't (although this sucks because then my computer acts like it has 2 displays and then things disappear to the 2nd non existant display like it does if i make my receiver do it)
So best solution will be sound card like i have now soundblaster but instead of optical out it has hdmi out. Currently using DTS connect w/ spdif optical out which works fine but the sound quality is not nearly as good as the uncompressed hd audio streams from newer tech.
Thanks
Thanks
