So i noticed that my super cheap AlphaCool Coolplex Pro 10LT tube reservoir has developed some small fractures in the acrylic around the top of the tube where it threads into the POM end cap, so i'm looking for a slightly taller (120-180mm) tube reservoir that isn't going to cost $100+ that has multiple top ports and one lower outlet. I have a feeling i probably tightened that top cap down a bit too much after cleaning it when i switched to acrylic tubing.
Anyways, after some searching i came across a couple of Barrow tube reservoirs, and since i really like their v4 compression fittings for hard tubing, i figured they'd probably make a nice res. They come in both acrylic or quartz glass so if anyone has had their hands on one of these, i'd like to know what you think about it. Looking at them at face value, i'm leaning towards the glass version.
Thanks
Thanks
