21 - 40 of 1,790 Posts
Rams works fine....Corsair Vengeance LPX DDR-4 16GB/3000 KIT (CMK16GX4M2B3000C15) ver.4.21..samsung... :)
Encouraging, hope my works better than now, 3200MHz but anything over and is not reliable. Will be joining the club next week when I get my MB.
Changed from x370 to x470 today. Looking good for now, passing benchmarks and not giving programs and windows hard time. Will run endurance tests tonight.
Yes, I tried 4011 but not as stable or able to get RAM to full speed. As both have AGESA 1.0.0.2a code I suspect it's the vulnerability protection (SMU 43.18) that is problematic. 4008 now and it's fine.
Hi guys,
I have a problem with my new Asus prime x470 pro. No signal at all from the hdmi port. I contacted the seller and he told me that this board needs an additional graphic card to work.
He says this happen "because i use a ryzen 2700x cpu!"
This sound very strange to me...but what is your opinion please?
Inviato dal mio LG-H930 utilizzando Tapatalk
Exactly, R7 2700x or any from those series do not have a GPU built in and need a dedicated graphic card. For now, only true Ryzen processors with GPU are 2200g and 2400g.
"Dont buy this board."- LOL ;)
I use this board and nothing issues and anything.. :)
Bios4008,water cooler....
And here my test videos:
https://www.youtube.com/channel/UCitu_Zn1xeowRTmR-Y0v_EQ
But i know there is problem with pwm fan controls and super io chip! :(
Hi, i have a question regarding that board in terms of overclocking a 2700x and the VRM temps,and yes i watched the video from the buildzoid guy...but i was not impressed by this burnout:devil:.
I don't want to burn anything while benching or testing stability! And that's the part on the video that might made me a bit frighten :rolleyes:
Also planning to place the parts in a Dark Base Pro rev.2 which should be in stores nearly 14 days.
Greetings
Greetings
Let me put it this way. 2700x at 4.25GHz and 1.4v (1.417 at 100% load) VRM temps <60c (<50c on the top of heat sink measured by IR thermometer). Tha's nowhere close to burning it.
Prime X470-Pro random and weird black screen
I built a new PC as below config last month and it started my nightmare.
The PC randomly black screen in low CPU usage and NO related errors in event views (it only shows "power off unexpected", "dump fail" etc.).
At the beginning, I thought it was caused by overclock. I disabled all overclock options in bios and win10, even Cool & Quiet, set performance bias to None or Auto. I used aida64, OCCT, Furmark, memtest, Fritz Chess, etc. to test for hours and days, NO black screen.
But when I start to use it with low workload (internet browsing, listening music, downloading, etc.) daily, it occurred black screen again.
Sometimes several times in one hour, sometimes one or two times in days.
And when the black screen occurs, I can PING that PC successfully and read the files/folders shared by that PC from another laptop/pc; it seems you can't remote desktop to that PC when black screen. Keyboard, mouse is dead (Caps Lock light didn't on / off when you press); no signal to TV or monitor, CPU fans and VGA, motherboard, chassis fans work as normal.
I can't reset the PC by press the RESET on chassis (it works when PC working normally), I only can press the POWER button for 3 seconds to power off the PC. And after I re-power on the PC, sometimes it ask you to enter BIOS.
The video card is from my another PC. It works well on that one for years. Memory is tested on other PC, no issue. I don't have a CPU to replace and test. But I think it's motherboard issue.
I almost try to change every settings in the BIOS to test, I didn't install AI Suite, any RGB software on my PC, no start HW monitoring tools.Tried ultimate power plan, ryzen power plan, performance power plan, no timers for sleep...... I try to set everything I could figure out. Sometimes I even believe I fixed it after using it without black screen for day, then it black screen again. :(
Please anyone can help me???
My build:
AMD Ryzen 2700x
Prime X470 pro BIOS 4011
Gskill DDR4 3200
AMD R9 370 4G HDMI to TV, DP to monitor
Win 10 Pro x64
