ASUS Rampage III Formula or Gigabyte G1 Sniper?
1 reading
4.8K views 24 replies 12 participants last post by  ntuason
#1 ·
I'm giving my DX58O in my sig rig, to a co-worker so im going to upgrade my x58 Board.
Im slowly Getting into PC Gaming, and Currently Have had no need to overclock my system, but I would like to be able to setup a nice moderate overclock at some point.
So I want a board with all the features, but dont need a $500+ super high OC board, like the rampage 3 black edition or X58A-OC
I Really Dont want to spend more than $300 on a board, but the extra cash doesnt bother me, if its worth it in the long run.
Ive Narrowed My Choices Down the
Asus Rampage III Formula
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131666&cm_re=rampage_3_formula-_-13-131-666-_-Product
Or
Gigabyte G1.Sniper
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128471
Current Rig is My Sig Rig. and I use spdif to my av reciver for audio, i dont plan on buying any expansion audio or nic cards, onboard only, and I'm currently leaning on an ASUS GTX 580 DirectCUII which takes 3 slots, but dont see myself ever going sli.
Originally I was dead set on the ASUS Rampage 3 Formula
Pro -It had a Good Intel Nic, and onboard Realtek Audio Chip, (compared to the RIII Extreme)
Pro -rog connect and good oc utitlies,
Pro -usb3/sata6,
Pro-has 7 PWM Fan connections, can bios controll all my fans in haf 932, plus room for more
ProHas good pci express placement for a three slot cooler
Con- I would have stick my OCZ Vertex2 on the intel 3GB sata port, due to issues all x58 boards have with the Marvel Sata 6 Ports.
But I just saw the Gigabyte G1 Killer Sniper Board and read some reviews on OCN about it
Pro - Apparently the G1 has a Newer Marvel Sata 6 Chip thats on par/better than the intel p67 sata6 chip
Pro-Has an awsome nic card, i download alot of files i say so any additonal network optimization is nice
Pro-onboard sound is even better
Pro-It has a USB 3.0 INternal Header, & comes with a front mount usb panel
Con-Only has 5 PWM fan connections, so no room for any addtl fans to connect onboard
Con-The color scheme is ok, but not a huge fan on the Gun look, kind of cheesy...I dont like the gun look
Con-No External BIOS Reset Button
Con-$140 More, But adding a separte nic and audio card to another board would cost more, so your paying for better onboard componets
...Hmmm...Which one would you go with...
Also does anything think any other MFG's might release a last Series of X58 Boards incorporating such tech as onboard usb 3.0 headers or the updated marvell sata 6 chip?
#2 ·
Rampage allways less cons, cheaper, better build and tend to last longer plus rma service is better in the small chance if it broken.
#3 ·
I just installed my Rampage III Formula this past week and have had no issues so far. It's been a great motherboard and very easy to overclock (which you should if you are gaming!!!). I've had no issues with my Crucial C300 SSD installed on a Sata III port. I just followed the recommendation of not installing the Marvel drivers after the initial Windows install and it's worked like a champ. I would definitely recommend the Rampage for sure.
#4 ·
I think im leaning back to the Ramapage after reading the Nic and the sound chip arent all that cracked up to be on the g1, and also it doesnt overclock any better at all, and I just figured that I already have more fans than headers on the g1 sniper and the asus has something like 7 fan headers.
I will make sure I use the windows drivers and not crappy marvell ones, i did read somewhere there drivers were the main issue.
Also after selling my dx58so, an e8500 proc i have, and some other cash im due...The Asus would be a $0 upgrade, which makes things even sweeter. Vs $150 out of pocket for the G1
#6 ·
i got the assassin and its a sick board, i love it, but of course it costs more. it OCes like every other X58 GB board OCes, like a beast. Id take it over the formula, but its personal choice. Totally different color schemes. i was able to push 231blck on my assassin, that is on air tho, probably could do more.
Its really brand preference at this point asus or gb its you pick. The asus is cheaper tho.
#9 ·
yea color is very important lol can't have a green PSU with green sleeving with a red board, or visa versa, it'll looks like a Christmas tree, unless you enjoy that.
When i used to mod cases, i would buy depending on color. Now i build around the board as its the most important component. many build around the GPU, or CPU, i pick the board.
#10 ·
Pro -usb3/sata6,
since you got a vertex2 there is no point of the SATA 6.0gbps port just chuck it on the SATA II
#11 ·
Its your fault, im stuck in this decison. Because of your Reviews.
Also im looking at the sniper, not the assassin.
I really like the G1 mainly becuase its the most up to date x58 board. It a revised marvell chip, onboard usb 3.0 with the front panel, a good sound card, (but this may not make any diff, becuase i use SPDIF to an external DAC) and the Killer Nic, but Ive heard mixed reviews on the Nic card drivers causing issues. I wouldnt be able to plug all my fans into the board and i heard the excpet for the killer nic and audio software, the rest of the gigabyte software is outdated and lacking
But asus board has a real good intel nic anyways and a better than avg realtek onboard solution and has 7 pwm headers
tough to justify the extra $150, and if i look at the sniper il tell myself why not spend an extra $100 for the assasin..lol
#12 ·
unless you upgrade your ssd with w/e that uses SATA 6gbps then the formula works fine
also for your fans use a fan splitter cable
#13 ·
I found that teh NIC helps, there is no deny that is works, it just works not so much. it speeds up what it can on your side of the thing, but once the pakcets are sent to teh internet nothing you can do. it does lower your ping in games, so that you don't lag, and your ping score looks better lol.
The easytune software is updated regularly from what it seems because before the G1 assassin there was no way to control the other fan ports. Its also a good OCing tool,. but yea it doesn't give such nice graphs and stuff that the ROG software does, but there is also dynamic energy saver and that gives you some pretty cool features. They update the software, but it doesn't have the looks the ROG stuff has. i had a R3E and a P6X58D-Premium, the ROG software is 100% better than the rest of asus's software, and i have been using asus boards for something like 7-8 years and software has always sucked, like pc probe so buggy. ROG software works tho.
The sound has an external ADC to go with your DAC, it will improve signal quality and it sounds like sound is important to you. I thought it was pretty damn nice, but then again i have crappy sound setup so yea it sounds nice when you add the amplifiers in, you aren't going to need the amplifiers onboard because you have your extremal DAc prob has one built in.
Like i said int eh other thread, you really are going to run more than like 5 fans? i run like 2 lol the CPU's and another for my case, and of course the GPUs have their own.
Honestly the boards are meant to be competitors, so they are head to head with the GB costing more, id go with a color combo you like lol, it sounds stupid but it makes sense b/c you seem to be pretty concerned with the general appearance of everything. The G1 series comes with cool accessories, idk if you like stickers but it has those as well, i still haven't done anything with mine, but i guess you can stick the bullet hole ones on your car hahahahahahaha some people really like the style. you gotta like what you buy, no one can make you like anything you can just take advise and educate yourself on it, but if you think you are going to regret something then don't get it.
on a side note i didn't know anyone reads my reviews hahaha i am sorry it put you in this dilemma
#14 ·
You have a very similar system.
How does your 970 work on that board? Whats speeds do you run it at?
Do you plug ur ssd in to marvel sata 6gb or the intel 3GB ports?
#15 ·
with any SATA3G SSD, like the vertex 2 you want to leave it in the ICH10R ports it performs best there you get no advantage at all from putting it in marvell sata6g. Only thing that benefits is a drive like the C300, which has higher 4k speeds on ICH10R, so many used to use their C300 SATA6G SSD on ICH10R for X58 platform, but with this new marvell many are using marvell now.
#16 ·
#18 ·
Go with the Rampage III Formula - awesome overclocker, great features, ROG connect is a very worth while feature (I have my netbook connected, allows for on the fly changes) - also Asus is very good with their warranty, and has a great Advanced Replacement option. Spacing worked perfectly for me, really a top end board with a great price!
#19 ·
Yesterday I was reading a pretty In depth review of the 2 boards. Overall the build quality of the Rampage III is higher. The VRM's and voltage regulation was consistantly better than the Gigabyte's (less oscillation).
To sum it up they said that the Gigabyte board ran a little cooler but the Asus's power distribution was superior.
#20 ·
5 vs. 7 PWM headers shouldn't be an issue either way. You can use 2 and 3-way PWM splitters to add fans, so I wouldn't let this be a major factor. Unless you really need 7 discrete control channels vs. 5, as all the fans on one splitter would be controlled as one.
#21 ·
I um actually know which you are referring tooTin's review, oh and asus gave him both boards. He just showed LLC on P67 systems lol, nothing to do with X58, GB's X58 LLC is perfect. Also B3 boards LLC is different. Notice Tin didn't say anything good about the P67A-UD7 other than it runs cooler. The GB rep on the website ripped him a new one. He even positioned teh cooler so that it woudln't fit right on the UD7, look closley.
#22 ·
I'm going to Buy the RIIF Board Tommorow at Microcenter...
Ive only owned Intel Boards, my roomate had a few gigabytes and I know thier top notch. But i think I'll see what the RIIIF is all abou. I'd like to try a high end asus board, i can always return/sell it and get the g1 later on, once more info pours in about it.
And its almost a Free Upgrade, after selling some other componets..always nice
Even tought I love Newegg, i dont want to deal with newegg's rma/return ship hassle espically for a motherboard. and its the same price instore. I'd also like to get w.e warranty MC offers..so I can excahnge it for store credit if something is ever wrong.
As for the Open Box Deal....I dont want to deal with missing items, from what ive heard about a few open box mobo's.....If its OB at microcenter....then i'll hop on it
#24 ·
They didnt have it instore..so i bought it from thier website......It was the same price. and it was only $30 for the instore 2year replacement plan. I work at another retail store, and its always nice just to be able to say something is wrong and have them just give you store credit. If i dont want to go through asus rma.
Or if i want a different board.lol
#25 ·
Woah! X58 has sata problems?
