I am trying to decide between these 2 boards. I want to get my build up ASAP and my local store only has the Extreme which is more expensive, but not too worried about that.
Is there any downsides of the Extreme vs the Apex.
Like I hear the Apex is best for overclocking and Extreme is also great and has more features?
Do they have same VRM. I believe they do?
Someone told me Extreme is not as good for RAM overclocking and even worse than Hero?? That concerns me the most?? Is this at all true? Though I am going to run DDR5 G.Skill Trident Z (16GB X 2) 6000MHZ 36-36-36-70 timings XMP i Gear 2 which is default settings of that RAM. I know that is XMP stock, but is technically considered overclocked just like CPU running at boost speed supported by manufacturer is considered overclocked.
Also is the build quality of either board better?
How are the VRM cooling on each? The same?
And does the Extreme have a backplate and does the Apex for more sturdy handling inside the case when plugging and unplugging things.
