Collection thread for the ASUS ROG Strix X670E Gaming WIFI series
Manufacturer page: STRIX X670E-E / STRIX X670E-F / STRIX X670E-A / STRIX X670E-I
Support/Driver/Bios (Manufacturer page): STRIX X670E-E / STRIX X670E-F / STRIX X670E-A / STRIX X670E-I
Support/Driver/Bios (Alternative): STRIX X670E-E / STRIX X670E-F / STRIX X670E-A
Geizhals: STRIX X670E-E / STRIX X670E-F / STRIX X670E-A / STRIX X670E-I
Geizhals Comparison: Strix X670E-E/F/A/I
ECO Mode Guide: AMD Eco Mode Guide for AM5 | Introduction and Initial Settings Pages | CPU & Mainboard
Reviews:
Reviews in anderer Sprache: [Sammelthread] - ASUS ROG Strix X670E-E/-F/-A/-I Gaming WIFI (AM5)
Special features:
- Optimized cooling design: Massive VRM heatsink plus integrated aluminum I/O cover, highly conductive thermal pad, L-shaped heatpipe, M.2 combo heatsink and M.2 backplate for PCIe® 5.0 M.2_1 slot, three onboard M.2 heatsinks and one massive M.2 heatsink as accessories
- Overclocking technologies: Dynamic OC Switcher, Ryzen Core Flex, Asynchronous Clock and PBO Enhancement.
- High-performance networking: Onboard WiFi 6E, Intel® 2.5Gb Ethernet and ASUS LANGuard
- Industry-leading audio: ROG SupremeFX ALC4080 with Savitech SV3H712 amplifier, along with DTS® Sound Unbound and Sonic Studio III
- Unmatched personalization: ASUS-exclusive Aura Sync RGB lighting, including one RGB header and three addressable Gen 2 RGB headers
- DIY-friendly design: power button, pre-assembled I/O shield, PCIe slot Q-release, M.2 Q-latch, Q-code, Q-LED, BIOS FlashBack™, Clr CMOS button, FlexKey, SafeSlot and SafeDIMM
- Intelligent control: ASUS-exclusive tools such as AI Cooling II, Two-Way AI Noise-Cancelation and AI Networking for easy configuration
- Renowned software: 60-day trial version of AIDA64 Extreme and intuitive UEFI BIOS dashboard included
Specifications ROG STRIX X670E-E GAMING WIFI:
AMD Socket AM5 for AMD Ryzen™ 7000 Series Desktop Processors*
* Refer to www.asus.com for CPU support list.
Chipset
AMD X670
Memory
4 x DIMM, Max. 128GB, DDR5
6400+(OC)/ 6200(OC)/ 6000(OC)/ 5800(OC)/
5600(OC)/ 5400(OC)/ 5200/ 5000/ 4800 ECC and Non-ECC, Un-buffered Memory*
Dual Channel Memory Architecture
Supports AMD EXTended Profiles for Overclocking (EXPO™)
OptiMem II
* Supported memory types, data rate(Speed),
and number of DRAM module vary depending on the CPU and memory configuration, for more information refer to www.asus.com for memory support list.
* Non-ECC, Un-buffered DDR5 Memory supports
On-Die ECC function
Graphics
1 x DisplayPort**
1 x HDMI® port***
**Supports max. 8K@60Hz as specified in DisplayPort 1.4.
***Supports 4K@60Hz as specified in HDMI 2.1.
Expansion Slots
2 x PCIe 5.0 x16 slots (supports x16 or x8/x4 modes)
AMD X670 Chipset
1 x PCIe 4.0 x16 slot (supports x4 mode)
Storage
Total supports 4 x M.2 slots and 4 x SATA 6Gb/s ports*
M.2_1 slot (Key M), type 2242/2260/2280 (supports PCIe 5.0 x4 mode)
M.2_2 slot (Key M), type 2242/2260/2280 (supports PCIe 5.0 x4 mode)
M.2_3 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 5.0 x4 mode))
AMD X670 Chipset
M.2_4 slot (Key M), type 2242/2260/2280 (supports PCIe 4.0 x4 mode)
*AMD RAIDXpert2 Technology supports both NVMe RAID 0/1/10 and SATA RAID 0/1/10.
Ethernet
1 x Intel® 2.5Gb Ethernet
ASUS LANGuard
Wireless & Bluetooth
Wi-Fi 6E
2x2 Wi-Fi 6E (802.11 a/b/g/n/ac/ax)
Supports 2.4/5/6GHz frequency band*
Bluetooth v5.2
* WiFi 6E 6GHz regulatory may vary between
countries, and function will be ready in Windows 11 or later.
**The Bluetooth version may vary, please refer to the Wi-Fi module manufacturer's website for the latest specifications
USB
Rear USB (Total 13 ports)
1 x USB 3.2 Gen 2x2 port (1 x USB Type-C®)
12 x USB 3.2 Gen 2 ports (10 x Type-A + 2 x
USB Type-C®)
Front USB (Total 9 ports)
1 x USB 3.2 Gen 2x2 connector
1 x USB 3.2 Gen 1 header supports additional 2 USB 3.2 Gen 1 ports
3 x USB 2.0 headers support additional 6 USB 2.0 ports
Audio
ROG SupremeFX 7.1 Surround Sound High
Definition Audio CODEC ALC4080
- Impedance sense for front and rear
headphone outputs
- Supports up to 32-Bit/384 kHz playback
Audio Features
front panel is required to support 7.1 Surround Sound audio output.
Back Panel I/O Ports
1 x USB 3.2 Gen 2x2 port (1 x Type-C®)
12 x USB 3.2 Gen 2 ports (10 x Type-A, 2 x USB
Type-C®)
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
1 x Intel® 2.5Gb Ethernet port
5 x Gold-plated audio jacks*
1 x Optical S/PDIF out port
1 x BIOS FlashBack™ button
1 x Clear CMOS button
*The rear panel Lime (Line out) port does not support spatial audio. If you wish to use spatial audio make sure to connect your audio output device to the audio jack on the front panel of your chassis.
Internal I/O Connectors
Fan and Cooling related
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
5 x 4-pin Chassis Fan header
Power related
1 x 24-pin Main Power connector
2 x 8-pin +12V Power connector
Storage related
4 x M.2 slots (Key M)
USB
1 x USB 3.2 Gen 2x2 connector (supports USB Type-C®)
Miscellaneous
3 x Addressable Gen 2 headers
1 x AURA RGB header
1 x Alteration Mode Switch
1 x CPU Over Voltage jumper
1 x Front Panel Audio header (AAFP)
1 x Start button
1 x 20-3 pin System Panel header with Chassis intrude function
1 x Thermal Sensor header
1 x Thunderbolt™ header
Special Features
Extreme Engine Digi+
- 5K Black Metallic Capacitors
ASUS Q-Design
- Q-Slot
ASUS Thermal Solution
ROG Exclusive Software
Armoury Crate
- TPU
WinRAR
UEFI BIOS
ASUS EZ DIY
FlexKey
BIOS
256 MbFlash ROM, UEFI AMI BIOS
Manageability
WOL by PME, PXE
Accessories
Cables
2x SATA 6Gb/s cables
Additional Cooling Kit
1 x Thermal pad for M.2
Miscellaneous
1 x ASUS Wi-Fi moving antennas
1 x Cable ties pack
1 x Massive M.2 Heatsink
1 x M.2 Q-Latch package for M.2 backplate
1 x ROG Graphics card holder
2 x Rubber Packages for M.2
1 x Rubber Package for M.2 backplate
1 x ROG key chain
1 x ROG Strix sticker
1 x ROG Strix thank you card
Documentation
1 x User guide
Operating System
Windows® 11 64-bit, Windows 10 64-bit
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )[
Chipset
AMD X670
Memory
OptiMem II
On-Die ECC function
Graphics
1 x DisplayPort**
1 x HDMI® port***
Expansion Slots
AMD X670 Chipset
Storage
AMD X670 Chipset
Ethernet
ASUS LANGuard
Wi-Fi 6E
Bluetooth v5.2
USB
USB Type-C®)
Audio
headphone outputs
- Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback
Audio Features
- Audio Shielding
- Savitech SV3H712 AMP
- Gold-plated audio jacks
- Rear optical S/PDIF out port
- Premium audio capacitors
- Audio cover
Type-C®)
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
Power related
Storage related
USB
Miscellaneous
1 x AURA RGB header
1 x Start button
Special Features
ASUS Q-Design
- M.2 Q-Latch
- PCIe Slot Q-Release
- Q-Code
- Q-DIMM
- Q-LED (CPU [red], DRAM [yellow], VGA
- Q-Slot
- M.2 heatsink backplate
- M.2 heatsink
- VRM heatsink design
- Massive M.2 Heatsink
- BIOS FlashBack™ button
- BIOS FlashBack™ LED
- Clear CMOS button
- ProCool II
- Pre-mounted I/O shield
- SafeSlot
- SafeDIMM
- AURA RGB header
- Addressable Gen 2 headers
- GameFirst VI
- ROG CPU-Z
- Sonic Studio III + Sonic Studio Virtual
- Sonic Radar III
- DTS® Sound Unbound
- Anti-virus software
Armoury Crate
- AIDA64 Extreme (60 days free trial)
- AURA Creator
- AURA Sync
- Fan Xpert 4 (with AI Cooling II)
- Power Saving
- Two-Way AI Noise Cancellation
- TPU
- DIGI+ VRM
- Turbo app
- PC Cleaner
WinRAR
UEFI BIOS
ASUS EZ DIY
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
- ASUS UEFI BIOS EZ Mode
FlexKey
BIOS
Manageability
WOL by PME, PXE
Accessories
Cables
Miscellaneous
1 x Cable ties pack
1 x ROG key chain
Documentation
1 x User guide
Operating System
Form Factor
ATX Form Factor
Specifications ROG STRIX X670E-F GAMING WIFI:
Chipset
AMD X670
Memory
4 x DIMM, Max. 128GB, DDR5 6400+(OC)/6200(OC)/ 6000(OC)/ 5800(OC)/ 5600(OC)/ 5400(OC)/ 5200/ 5000/ 4800 ECC andNon-ECC, Un-buffered Memory*
OptiMem II
Graphics
1 x DisplayPort*
1 x HDMI® port**
* Supports max. 8K@60Hz as specified in DisplayPort 1.4.
**Supports max. 4K@60Hz as specified in HDMI 2.1.
Expansion Slots
1 x PCIe 5.0 x16 slots (supports x16 mode)
AMD X670 Chipset**
1 x PCIe 3.0 x1 slot
* Please check PCIe bifurcation table in support site ([Motherboard] Compatibility of PCIE bifurcation between Hyper M.2 series Cards and Add-On Graphic Cards | Official Support | ASUS Global).
Storage
AMD X670 Chipset
M.2_3 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 4.0 x4 mode)
*AMD RAIDXpert2 Technology supports both PCIe RAID 0/1/10 and SATA RAID 0/1/10.
Ethernet
ASUS LANGuard
Wi-Fi 6E
Bluetooth v5.2
* WiFi 6E 6GHz regulatory may vary between countries.
USB
Rear USB (Total 12 ports)
9 x USB 3.2 Gen 2 ports (7 x Type-A + 2 x USB Type-C®)
2 x USB 2.0 ports
Front USB (Total 7 ports)
2 x USB 2.0 headers support additional 4 USB 2.0 ports
Audio
ROG SupremeFX 7.1 Surround Sound High Definition Audio CODEC ALC4080
9 x USB 3.2 Gen 2 ports (7 x Type-A, 2 xUSB Type-C®)
2 x USB 2.0 ports
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
5 x 4-pin Chassis Fan headers
Power related
Storage related
4 x SATA 6Gb/s ports USB
Miscellaneous
1 x Aura RGB header
1 x Thunderbolt™ (USB4®) header
Special Features
ASUS Q-Design
- Q-Slot
Armoury Crate
TPU
DIGI+ VRM
Turbo app
PC Cleaner
MyAsus
WinRAR
UEFI BIOS
ASUS EZ DIY
FlexKey
BIOS
256 Mb Flash ROM, UEFI AMI BIOS
Manageability
WOL by PME, PXE
Accessories
Cables
2 x SATA 6Gb/s cables
Miscellaneous
1 x Cable ties pack
1 x ROG key chain
1 x ROG Strix stickers
Documentation
1 x User guide
Operating System
Windows® 10 64-bit, Windows® 11 64-bit
Form Factor
ATX Form Factor
Chipset
AMD X670
Memory
OptiMem II
- Supported memory types, data rate(Speed), and number of DRAM module vary depending on the CPU and memory configuration, for more information refer to www.asus.com for memory support list.
- Non-ECC, Un-buffered DDR5 Memory supports
Graphics
1 x DisplayPort*
1 x HDMI® port**
Expansion Slots
AMD X670 Chipset**
Storage
AMD X670 Chipset
Ethernet
ASUS LANGuard
Wi-Fi 6E
Bluetooth v5.2
USB
2 x USB 2.0 ports
Audio
- Impedance sense for front and rear headphone outputs
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input
- Supports up to 32-Bit/384 kHz playback"
- Audio Shielding
- Audio cover
2 x USB 2.0 ports
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
Power related
Storage related
Miscellaneous
1 x Aura RGB header
Special Features
ASUS Q-Design
- M.2 Q-Latch
- Q-DIMM
- Q-Slot
- M.2 heatsinks
- Clear CMOS button
- ProCool II
- SafeSlot
- SafeDIMM
- Aura RGB header
- GameFirst VI
- ROG CPU-Z
- Sonic Radar III
Armoury Crate
- Aura Creator
- Aura Sync
- Power Saving
TPU
DIGI+ VRM
Turbo app
PC Cleaner
MyAsus
WinRAR
UEFI BIOS
ASUS EZ DIY
- ASUS EZ Flash 3
FlexKey
BIOS
Manageability
WOL by PME, PXE
Accessories
Cables
Miscellaneous
1 x Cable ties pack
1 x ROG key chain
Documentation
1 x User guide
Operating System
Form Factor
ATX Form Factor
Specifications ROG STRIX X670E-A GAMING WIFI:
Chipset
AMD X670
Memory
4 x DIMM, Max. 128GB, DDR5 6400+(OC)/ 6200(OC)/ 6000(OC)/ 5800(OC)/ 5600(OC)/ 5400(OC)/ 5200/ 5000/ 4800 ECC and Non-ECC, Un-buffered Memory*
Dual Channel Memory ArchitectureSupports AMD EXTended Profiles for Overclocking (EXPO™)OptiMem II
1 x DisplayPort*
1 x HDMI® port**
** Supports Supports 4K@60Hz as specified in HDMI 2.1.
*** VGA resolution support depends on processors' or graphic cards' resolution.
Expansion Slots
1 x PCIe 5.0/4.0/3.0 x16 slot
AMD X670 Chipset
1 x PCIe 4.0/3.0 x16 slot (supports x4 mode)
Storage
AMD X670 Chipset
Ethernet
ASUS LANGuard
Wi-Fi 6E
Bluetooth v5.2
* WiFi 6E 6GHz regulatory may vary between countries, and function will be ready in Windows 11 or later.
USB
8 x USB 3.2 Gen 2 ports (7 x Type-A + 1 x USB Type-C®)
1 x USB 3.2 Gen 1 port (1 x Type-A)
2 x USB 2.0 ports (2 x Type-A)
1 x USB 3.2 Gen 2x2 connector (supports USB Type-C® )
Audio
8 x USB 3.2 Gen 2 ports (7 x Type-A, 1 x USB Type-C®)
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
1 x Intel® I225-V 2.5Gb Ethernet port
5 x Audio jacks
Power related
Storage related
USB
2 USB 3.2 Gen 1 ports2 x USB 2.0 headers support additional 4 USB 2.0 ports
Miscellaneous
1 x Aura RGB header
Special Features
ASUS Q-Design
ASUS EZ DIY
AURA Sync
ASUS Exclusive Software
Armoury Crate
WinRAR
UEFI BIOS
ASUS EZ DIY
BIOS
Manageability
WOL by PME, PXE
Accessories
Cables
Miscellaneous
1 x Cable ties pack
1 x M.2 Q-Latch packages for M.2 backplate
1 x ROG key chain
Documentation
1 x User guide
Operating System
Windows® 11, Windows® 10 64-bit
Form Factor
ATX
Chipset
AMD X670
Memory
- Non-ECC, Un-buffered DDR5 Memory supports On-Die ECC function
1 x DisplayPort*
1 x HDMI® port**
Expansion Slots
AMD X670 Chipset
Storage
AMD X670 Chipset
Ethernet
ASUS LANGuard
Wi-Fi 6E
Bluetooth v5.2
USB
Audio
- SupremeFX Shielding Technology
- Audio cover
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
5 x Audio jacks
Power related
Storage related
USB
Miscellaneous
1 x Aura RGB header
Special Features
ASUS Q-Design
- M.2 Q-Latch
- Q-DIMM- Q-LED (CPU [red], DRAM [yellow], VGA [white], Boot Device [yellow green])
- Q-Slot
- M.2 heatsink
ASUS EZ DIY
- Clear CMOS button
- ProCool II
- SafeSlot
- SafeDIMM
AURA Sync
- AURA RGB header
- GameFirst VI
- ROG CPU-Z
- Sonic Studio III + Sonic Studio Virtual Mixer + Sonic Suite Companion
- Sonic Radar III
Armoury Crate
- AURA Creator
- AURA Sync
- Power Saving
- TPU
- DIGI+ VRM
- Turbo app
- PC Cleaner
WinRAR
UEFI BIOS
ASUS EZ DIY
- ASUS EZ Flash 3
BIOS
Manageability
WOL by PME, PXE
Accessories
Cables
Miscellaneous
1 x Cable ties pack
1 x ROG key chain
Documentation
1 x User guide
Operating System
Form Factor
ATX
Specifications ROG STRIX X670E-I GAMING WIFI:
Chipset
AMD X670
Memory
2 x DIMM, Max. 64GB, DDR5 6400+(OC)/ 6200(OC)/ 6000(OC)/ 5800(OC)/ 5600(OC)/ 5400(OC)/ 5200/ 5000/ 4800MHz ECC and Non-ECC, Un-buffered Memory*
OptiMem II
1 x HDMI® port*
2 x USB4® ports support USB Type-C® display
outputs**
2.1.
Expansion Slots
1 x PCIe 5.0 x16 slot(s)
Storage
Total supports 2 x M.2 slots and 2 x SATA 6Gb/s ports*
M.2_1 slot (Key M), type 2280(supports PCIe 5.0 x4 mode)
AMD X670 Chipset
2 x SATA 6Gb/s ports****
NVMe RAID 0/1 and SATA RAID 0/1.
**** Install ROG FPS-II Card to support 2 x
SATA 6Gb/s ports
Ethernet
ASUS LANGuard
Wi-Fi 6E
Bluetooth v5.2
USB
Rear USB (Total 10 ports)
2 x USB4® port(s) with Intel® JHL8540 USB4®
controller (2 x USB Type-C®)
5 x USB 3.2 Gen 2 port(s) (5 x Type-A)
3 x USB 2.0 port(s) (3 x Type-A)
Front USB (Total 3 ports)
1 xUSB 3.2 Gen 2 connector (supports USB Type-C®)
1 x USB 3.2 Gen 1 header(s) support(s)
ROG STRIX HIVE (Total 2 ports)
1 x USB 3.2 Gen 2 port(s) (1 x USB Type-C®)
1 x USB 2.0 port(s) (1 x Type-A)
ROG FPS-II C (Total 3 ports)
2 x USB 2.0 header(s) additional 3 USB 2.0
ports**
Audio
ROG High Definition Audio CODEC ALC4050
5 x USB 3.2 Gen 2 port(s) (5 x Type-A) (1
port supports ROG STRIX HIVE)
1 x HDMI® port
1 x Wi-Fi Module
1 x 4-pin CPU Fan header(s)
1 x 4-pin AIO Pump header(s)
1 x 4-pin Chassis Fan header(s)
Power related
1 x 8-pin +12V Power connector
Storage related
2 x M.2 slots (Key M)
USB
1 x USB 3.2 Gen 2 connector (support(s) USB
Type-C® )
Miscellaneous
1 x Addressable Gen 2 header(s)
1 x AURA RGB header(s)
1 x RTC Battery header
1 x 2 pin Power_BTN header
2 x USB Type-C® connectors to Install ROG
FPS-II card*
ROG FPS-II card
1 x Clear CMOS header
1 x Front Panel header
1 x Alteration mode switch
2 x USB 2.0 header(s) support(s) additional
3 USB 2.0 ports
Special Features
-5K Black Metallic Capacitors
ASUS Q-Design
1 x USB Type-C® connects to Motherboard
1 x USB 2.0 port(s) (1 x Type-A with BIOS
FlashBack™)
1 x Headphone jack with Mic in
1 x Mic in jack with Optical S/PDIF out
1 x EZ mode PBO button
1 x FlexKey button
1 x Volume Control Knob with Mute Button
Software Features
Armoury Crate
WinRAR
UEFI BIOS
ASUS EZ DIY
FlexKey
BIOS
Manageability
WOL by PME, PXE
Accessories
Cables
1 x ROG USB2.0 splitter cable
1 x Panel Cable
ROG FPS-II Card
1 x ROG FPS-II Card
ROG STRIX HIVE
1 x ROG STRIX HIVE
1 x USB Type-C® power connection cable
Miscellaneous
1 x Cable ties pack
1 x Rubber Package(s) for M.2
1 x Q-Latch package(s) for M.2
1 x ROG key chain
Installation Media
1 x User guide
Operating System
Form Factor
Mini-ITX Form Factor
6.7 inch x 6.7 inch( 17cm x 17cm)
Chipset
AMD X670
Memory
OptiMem II
1 x HDMI® port*
outputs**
2.1.
Expansion Slots
Storage
AMD X670 Chipset
SATA 6Gb/s ports
Ethernet
ASUS LANGuard
Wi-Fi 6E
Bluetooth v5.2
USB
ports**
Audio
- High quality 118 dB SNR stereo playback output and 94 dB SNR recording input
- ROG Hyper-Grounding Technology
- ESS® SABRE9260Q DAC
- Silver-plated audio jacks
- Optical S/PDIF out port & USB Type-C® port with indepent power solution
- Dedicated audio PCB layers
1 x HDMI® port
1 x Wi-Fi Module
Power related
Storage related
USB
Type-C® )
Miscellaneous
FPS-II card*
ROG FPS-II card
3 USB 2.0 ports
Special Features
ASUS Q-Design
- M.2 Q-Latch
- Q-DIMM
- Q-Slot
- M.2 heatsink
- Aluminum backplate
- M.2 Chipset Fan
- ProCool II
- SafeSlot
- SafeDIMM
- AURA RGB header(s)
- Addressable Gen 2 header(s)
FlashBack™)
1 x FlexKey button
Software Features
- GameFirst VI
- ROG CPU-Z
- Sonic Radar III
Armoury Crate
- AURA Creator
- AURA Sync
- Power Saving
- TPU
- DIGI+ VRM
- Turbo app
- PC Cleaner
WinRAR
UEFI BIOS
ASUS EZ DIY
- ASUS EZ Flash 3
FlexKey
BIOS
Manageability
WOL by PME, PXE
Accessories
Cables
1 x Panel Cable
ROG FPS-II Card
1 x ROG FPS-II Card
ROG STRIX HIVE
1 x ROG STRIX HIVE
Miscellaneous
1 x Cable ties pack
1 x ROG key chain
Installation Media
1 x User guide
Operating System
Form Factor
FAQ:
- Q: How to install Windows 11 22H2 if LAN is not detected?
- A: See the solution from Asus..
- Q: There is an unknown device in the device manager?
- A: it is the "Cypress UCM Client Peripheral" (AMD I2C).
If changes or additions are desired please inform me.
