Asus VG248QE 144hz 1ms TN 1080p
457K views 2.2K replies 341 participants last post by  blaze2210
"I just tried to play some CS GO havent tested lightboost, using 144Hz. Even at 120hz its like so much more dno how tosay smooth I guess
I hooked up my 700D again after and its like im playing on such lower hz again, and if you hook up a 60hz after you cry
Yea I think about AG removal, will use it like this for now. in windows and other games I might like glossy more but then in some games AG is actually nice... in CS GO for example I like my AG coating."
Its hard for me to believe you felt such a big different as you describe lol, altho I might get this monitor cause of LB but I wouldnt expect a different from 120 to 144. I noticed HUGE diff in 2 q3 engine based games and Counter strike from 60hz to 120hz. I cant even imagine it being smoother lol. But its nice to hear this monitor is that good anyhow
Switch to 1920X1080 (Obviously, your native resolution) and set it to 120Hz instead of 144Hz then run CRU and do everything as in the picture I posted then reboot. (CRU will write you to do so)
If your asking what happens if I keep it on 144Hz before entering CRU or what happens in case you change to 144Hz, I dont know
Today I was just browsing the internet and my screen went off for 2 seconds and there was this USB-plug unplugg sound(?) and then it came back?
Why would it make USB sound and screen go off? Is it something to worry about?
