This is a mini review of the Atrix Extreme Power 720 Watt PSU (Model 720THE)
This PSU has plenty of power to run most Midrange systems out there with no problem at all, this is a switching PSU with active PFC and dual 12v rails.
This PSU has a hony combed Rear vent to allow a good amount of airflow and has a 120mm fan that is not LED.
Power Specs
+3.3V - 28A
+5V - 30A
+12V1 - 20A
+12V2 -20A
+5VSB - 2.5A
-12V 0.3A
connectors
4 x SATA
4 x MOLEX
1 x 20/24
1 x FDC
2 x 6pin
1 x 4 pin
I have been using this PSU for about two days with not one problem at all and have been playing games on my system, my system has two optical drives one HDD a Radeon HD 4850, dedicated sound card and AMD Athlon x2 5000+ @ 3.1Ghz.
I would rate this PSU 4/5 the reason for this is because its a cheaper PSU I wouldn't like to push it to much to its max of 720 watt all the time but I can see this would run fine at a max of about 600 watts.
You can buy this PSU from Amazon for ÂŁ45.32 : [ame="[URL=http://www.amazon.co.uk/gp/redirect.html?ie=UTF8&linkCode=ur2&camp=1789&creative=9325&tag=overclockdotnet-20&location=http%3A%2F%2Fwww.amazon.co.uk%2FAtrix-Black-Silent-Power-Supply%2Fdp%2FB000O3ADQE%2Fref%3Dsr_1_3%3Fie%3DUTF8%26qid%3D1306512033%26sr%3D8-3]http://www.amazon.co.uk/Atrix-Black-Silent-Power-Supply/dp/B000O3ADQE/ref=sr_1_3?ie=UTF8&qid=1306512033&sr=8-3"]BUY[/ame[/URL]]
Edit: This PSU cost me ÂŁ19.00 + ÂŁ4.50 P+P from eBay
FYI: The PSU is now in the trash started making a humming sound that was getting louder.
