Hi!
I wanted to know if there are any difference between using cables AWG18 instead of AWG16 .
It turns out, that the original wires of Platimax (AWG 16) for HDD'S, DVD'S ....... are very difficult to sleeve for his type of connector, and if I leave them as is, the multicolor theme would not go well with my mod.
So I made my custom cables, but with AWG18 , then I will use their own original 5-pin connector from the PSU.
There will be some risk?
With respect to order and placement will not matter, right? They will be placed just as they are original cables.
Thank you!
Thank you!
