Bad Samsung 960 Evo M.2 NVMe SSD
3.1K views 12 replies 5 participants last post by  speedygs
#1 ·
I've run a few benchmarks and found that my M.2 SSD is underperforming quite significantly.
Does anyone know if this is just a bad drive, or if this is a software issue? Fresh build, fresh install of windows and all chipset drivers updated. NVMe SSD driver & firmware updated to latest.
Also here: http://www.userbenchmark.com/UserRun/5573248
Here is what one should expect from this drive:
#4 ·
Some notes from Asus
1 x M.2 Socket 3 with M Key, type 2242/2260/2280 storage devices support (SATA mode & X4 PCIE mode)
1 x M.2 Socket 3 with M Key, type 2242/2260/2280 storage devices support (PCIE mode only)
*1. The M.2_1 socket shares SATA_1 port when use M.2 SATA mode device. Adjust BIOS settings to use a SATA device.
*2. The M.2_2 socket shares SATA_56 ports when use M.2 PCIE mode device in X4 mode. Adjust BIOS settings to use M.2 PCIE devices in X4 mode.
Which slot do you have it in?
#5 ·
It's currently in M.2_1. I'll switch it over to M.2_2 as I only just discovered it, concealed under a heatsink which looked like it was mostly decoration
#6 ·
I also noticed that my SSD is says "stornvme" while the other one says "secnvme"
Can someone tell me the difference? I believe stornvme is windows related whereas secnvme is samsungs driver... Though I installed all the drivers from samsung mine still says stornvme.
#7 ·
My 500GB 960 is using secnvme with the 2.3 driver from Samsung, i believe you are right about stornvme being the M$ driver from a quick google search of that name......
