Bent usb 3.0 pin on my motherboard, the ports dont work. Help?
11K views 14 replies 7 participants last post by  Jolly Roger
#1 ·
As you can see my usb 3.0 pin (top left) is damaged. The ports on the front of the case dont work. Do you have any syggestions how to bend it back? I tried with a needle and a credit card, but it didnt work to well...
This is a hard to reach place.
#11 ·
Originally Posted by stringcheese166 View Post
That's genius! And I'm surprised the wire worked did you solder it or just rest it in the hole? Because you may end up with some latency or power issues down the road.
Wires work for a lot of things using these pins. I've actually gotten an AM2 processor with a broken off pin working again by sticking some copper wire into the pin hole that the processor pin would generally go into. It's magic.
#12 ·
I know, right!
I the only thing I did was that I removed the rubber casing, tangled it quite tight and stuck it into the plug. I also made shure that it's not touching other pins.
It's stuck there quite tight, so I shouldnt expirience any power issues, I mean as long as there is conduction, it will work.
And I'm happily using my front panel usb 3.0 connector! (with pendrives, mouces and headsets!)
#13 ·
I was doing some cable mods on my case wires and accidently clipped a wire that goes to my front panel audio plug. It was so close to the plug that there was no hope of splicing it. So I just hooked a little bit longer wire to the cut end and stripped its end and then stuck the wire into the plug from the other end. So when I plug it in it makes contact with the pin! Gotta love these jimmy-rig mods!
