Hi,
Have the h115i Capellix with a loud pump. The noise is pretty annoying, and I see on the web, there are many others who have the same issue, pump whine. Pump does not go below 2300 RPM.
I want to replace this AIO ASAP, with return window still open. Need some help in getting a replacement 280mm AIO.
Choices I'm considering (please no pump whine or noise) :
NZXT X63 or Z63
Rad too thick: Arctic Freezer II 280mm - clearance is already an issue, so I think this AIO is out of the question. Want to keep it as top mount.
NZXT X63 or Z63
