I need to upgrade my older AMD based pc I built in early 2014 soon and think I would rather go with a good prebuilt this time mostly to make sure everything is put together right with the airflow and cable management optimized. I think I know what components I want. I was thinking at least a Rysen 5600X, 16GB ram, 3060ti card, 750w power, a 500GB SSD for boot up and a 1TB HDD for storage and good airflow with some RGB fans (new to me as I've never had them) and a decent sound card. I have not idea what motherboard to get and new to overclocking too and not sure if its needed. My plans for use is general streaming, watching movies, music and I may get back into gaming at some point. I just want something more up to date that will be good to go for many years. I've been searching for about 5 or 6 weeks now and was originally going to go with something like ibuypower or Cyberpowerpc, but heard they were more toward the low end. I then found some places like CLX, Xotic, Xidax and Digital Storm that all look good and was going to go with one of those.
But I just noticed that HP came out with the Omen 45L that looks awesome and a quick build looks like I could put together a rig with slightly better components than the other places for around the same price (looking at staying right around 2k max or below). What do you guys think of it? My main concerns is that the warranty isn't as good as the dedicated gaming places because you have to pay for extended tech support (which I probably will need), while most of the other places have free tech support for life plus most likely less bloatware. BTW, I would also like to get a new keyboard, speakers with a subwoofer or soundbar and also a better monitor at some point and will need advice on what games to start with so I pretty much need the works.
